Which Flywheel?
Old Aug 24, 2009 | 07:57 PM
DenverFlash's Avatar
Which Flywheel?
I need to buy a new flywheel for my 350 Olds engine (1972) so I can install a TREMEC 5-speed. The flywheel manufacturers offer both internal- and external-balance flywheels, but I don't know which type I need. When I ask them which I need, I get doublespeak which makes me think they don't know either. The engine is mostly stock and originally had an automatic trans. Can anyone here tell me which type this engine requires?
Old Aug 24, 2009 | 09:26 PM
64Rocket's Avatar
external balance
You also need to drill the crank for a pilot bearing
Gene
Old Aug 24, 2009 | 09:39 PM
gearheads78's Avatar
car guy
You can also try the adapter bearing. Knock on wood it holding up so far in mine.
Crankshaft Pilot Bearing Conversion Auto Crank
Stick shift pilot bearing adapter. A new solution to an old problem. Convert a GM automatic transmission crankshaft to a manual shift crank without taking the crank out of the block. Knurled for a sure fit with self alignment for a perfect fit and smooth running and shifting. Requires modest shortening of input shaft with common tools. Also for engines that are using a midplate resulting in the transmission being moved rearward and not engaging the stock pilot bearing far enough. Fits Oldsmobile 260-455, Buick 350-455, Cadillac 400-500, Pontiac 326-455, and Chevrolet 305-502.
$42.00
Old Aug 24, 2009 | 10:31 PM
64Rocket's Avatar
That adapter bearing is what I use, I also drill the crank end so the input shaft will not have to be cut. I use a hand drill and drill the center until it is the size a bit bigger than the input shaft.
Gene
Old Aug 25, 2009 | 06:32 AM
"Internal" and "external" balance are Chevy terms that do not apply to Oldsmobiles unless you are doing custom parts swapping and balancing. There are only two different Olds flywheels, the 64-67 style and the 68-90 style. The difference is in the crank flange bolt pattern.
Old Aug 25, 2009 | 06:52 AM
Thanks. Yes I've got my bearing and have drilled the crank for clearance.
The aftermarket manufacturers do offer flywheels for both internal and external balance Olds engines, so I am thinking the internal-balance types are for custom-built engines that are internally balanced.
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
thomaswatk
Mar 22, 2007 01:31 PM
Jokers69
Oct 5, 2006 03:00 AM
tndonor
Jul 12, 2006 01:07 PM
