Fuel and brake lines
Old May 29th, 2021, 10:49 AM
tkcutlass's Avatar
Getting ready to purchase fuel and brake lines for my 70 cutlass convertible project.
Here's what I am looking at.
https://www.getdiscbrakes.com/cin7022s
https://www.getdiscbrakes.com/akt7003s
https://www.getdiscbrakes.com/agl7003s
Thoughts/ Comments what am I missing?
tkcutlass is online now
Old May 29th, 2021, 11:13 AM
Is the car an original disc brake car, or was it converted? Does it have the OEM metering valve under the M/C, or the 1971-up combo valve on the frame rail? Or does it have the aftermarket combo valve on a bracket under the M/C?
If you buy lines for a 1970 with OEM disc brakes, they will only fit the OEM configuration with the metering valve at the M/C and the distribution block on the frame. If you have the combo valve on the frame, get lines for a 1971. If you have an aftermarket conversion with a non-stock valve location, get lines for that specific aftermarket kit.
joe_padavano is offline
Old May 29th, 2021, 11:14 AM
70W-32's Avatar
Very happy with my Right Stuff brake and fuel lines.
If you havent checked yet, try those part numbers at Summit Racings website, might be a few bucks cheaper
70W-32 is offline
Beer Connoisseur
70cutty's Avatar
Fuel lines are fine.
Brake lines, that's not a complete set, not sure if you need a complete set or not. If you need a complete set, call them so you can tell them the position of the proportioning valve.
Also stainless brake lines are a major PIA to seal, I did that once and never again.
70cutty is offline
Old May 29th, 2021, 11:57 AM
tkcutlass's Avatar
Joe based on an old post by a trustworthy guy
Hopefully not outdated.
It's going with
https://www.speedwaymotors.com/Stock...-Kit,4624.html
https://www.speedwaymotors.com/1964-...ugg_q=91034900
Now for the rear that gets kinda complicated.
Best I can tell the 3.55 rear I picked up has the Right Stuff disc conversion kit. (been trying to get info from OO/ part numbers to no avail)
I will be needing a appropriate M/C, booster, and valve as well.
Old May 29th, 2021, 01:50 PM
If you're going with a four wheel disc conversion, you need a master cylinder and combo valve to match. The hard lines on the rear axle will need to be custom made to fit your axle, so get some practice on bending and flaring. The location you pick for the combo valve will dictate which line kit you need.
Old May 30th, 2021, 04:37 AM
Rallye469's Avatar
Also Right Stuff sells a COMPLETE brake line kit that cheaper than all the lines separate. Ask them about it.
You didn’t have the rear axle lines OR the rubber line from the rear to the axle which you might need.
-peter
Rallye469 is offline
brotherGood
June 25th, 2021 09:26 AM
highschoololds
Brakes/Hydraulic Systems
February 7th, 2020 05:05 PM
Federated52
January 26th, 2018 02:14 PM
servexcell
October 6th, 2017 04:54 AM
sawfilm
April 5th, 2017 05:37 AM
Quick Reply: Fuel and brake lines
