L 69 pics
Old Feb 27, 2020 | 09:40 AM
w-30dreamin's Avatar
71 & 72,now I want a 68
L 69 pics
Just when I'm thinking I have this set up done I realize my paint work was bad on the intake.
In regular indoor lighting and outdoor lighting it looked great,I put a bright light directly on it to help improve pics and I can see where the paint is thin on the side of the intake runners.
I'll be taking it apart to touch up the paint but overall looks much better now!
Sparky with Sparkys carb service gets most of the credit for the work he did restoring the carbs and hardware,they look amazing!
Old Feb 27, 2020 | 10:02 AM
Guy Fillinger's Avatar
Sparky does good work. What do you plan to put it on and are you going to go all the whay and get the glass fuel bowl and tall oil filler tube?
Old Feb 27, 2020 | 10:22 AM
For my application I won't use the tall fill tube and glass bowl.
I'm putting it on a 461 with a lot of bling for weekend rides and cruise ins in the gold 71 in my sig pic.
A pre build mock up of the 461
Old Feb 27, 2020 | 10:30 AM
NICE!!! That engine would also look good in a glass topped coffee table so you could look at it every day without leaving your living room.
Old Feb 27, 2020 | 11:39 AM
That's the same thing my son said lol
thank you very much.
Old Feb 28, 2020 | 05:33 AM
Run to Rund's Avatar
For the AL and AU Tri-Carb intakes, Olds published a note to use Permatex #1 on the center carb base gasket to help prevent vacuum leaks. That is because the passage in the base isn't fully supported by the pad on the manifold.
Old Feb 28, 2020 | 06:18 AM
Thank you very much for sharing this info.
I have seen you mention this in the past and I did take note,I will be using permatex.
thanks!
dennis_30281
Jan 29, 2019 05:29 PM
Toms65
Nov 21, 2018 07:56 PM
bonezarally
Jul 12, 2011 08:47 AM
Alb
Jun 29, 2011 04:43 AM
65az
Mar 20, 2009 12:19 PM
