PCV grommet install
Old Nov 18, 2019 | 04:36 PM
Rocket Olds's Avatar
PCV grommet install
Have a '67 CS 442 and have to replace PCV grommet and finally found the correct style and am having hard time getting to push it in place. I see someone suggested soapy water but still too stiff. any other suggestions on how to install new grommet? thanks, Mike
Old Nov 18, 2019 | 04:39 PM
RandyS's Avatar
Warm it up in hot water.
Old Nov 18, 2019 | 04:44 PM
thanks for fast reply. sounds like a plan. I will even try with hot soapy water for the best of both worlds. You guys are the best, thanks. I will report back in a few days when I get time to try it.
Old Nov 18, 2019 | 05:16 PM
I use silicone grease, not soapy water. Silicone won't attack the rubber the way petroleum greases will.
Old Nov 19, 2019 | 05:56 AM
Thanks, between all suggestions it is bound to work. I will report back
Old Nov 27, 2019 | 05:05 PM
pcv grommet
finally got around to the install of PCV grommet and the results are in, heating it up in hot water (actually brought to a boil and then took it out) and with the help of my kitchen ware round ended knife I was able to force it into the hole. The only issue was making sure it was lined up correctly with the opening and pushed all the way back into the opening and with a little persuasion from the knife it went in. Thanks for the help and as usual you guys are the greatest. Thanks, Mike
tiger85
Jul 17, 2018 05:30 AM
rustyroger
Tech Editor's Desk
Oct 10, 2013 06:49 PM
DeltaDevil88
Aug 3, 2013 04:48 PM
1973oldsomega
Mar 23, 2009 08:31 AM
Oldsmofjord
Jul 30, 2007 04:58 AM
