have you ever seen such an engine core repair?
Old Oct 19, 2019 | 02:59 AM
exotec's Avatar
Olds Omega
found the nightmare today under oil and dirt
Old Oct 19, 2019 | 05:12 AM
jcdynamic88's Avatar
that's very ambitious,i have seen maybe one hole drilled and tapped.time for 8 cylinders.
Old Oct 19, 2019 | 05:51 AM
scrappie's Avatar
I need help understanding what Im looking at? Is that a repair for a cracked block and how does that work?
Ive seen drill stop holes drilled in sheet metal to try and stop cracks, is this the same thing?
Old Oct 19, 2019 | 05:52 AM
The use of tapped plugs to repair a crack in cast iron is not uncommon, but that's not how it's done. To do it correctly, you start at one end of the crack, drill and tap to install a plug, then continue with subsequent plugs that overlap the prior ones. Obviously that's not what was done here. If you plan to keep the six, now's a good time to look for a 292 short block.
Old Oct 19, 2019 | 05:56 AM
exotec's Avatar
Olds Omega
...... If you plan to keep the six, now's a good time to look for a 292 short block.
yes, sir. this is what I'm going for.
Old Oct 19, 2019 | 06:33 AM
RetroRanger's Avatar
72 Olds CS
Crazy, but I guess it worked, if the repair was covered w oil n grease it must have some time on it.
Old Oct 19, 2019 | 07:56 AM
Tedd Thompson's Avatar
I've never seen that many(11) tapped screws done like that but stranger things have been McGivered by shade tree mechanics. It's probably a victim of I'll drain the radiator and then forget to drain the block syndrome. May have held for years, or not....Tedd
Old Oct 19, 2019 | 06:38 PM
classicmuscle442's Avatar
Have seen metal stitching before but nothing like this, bummer for you Ted.
Old Oct 19, 2019 | 08:22 PM
72455442RA's Avatar
repair work
the same shop musta worked on the brakes of this 69 Lemans I just picked up also ..
I about fell over laughin" ... whew ?? ,,, both sides !!
Old Oct 20, 2019 | 03:13 AM
toymobile's Avatar
GMC made a 305 six if you can find one.
Old Oct 20, 2019 | 05:14 AM
wr1970's Avatar
What happened was as crack kept growing more plugs were added.😀 they should have welded it. Jmo
Old Oct 20, 2019 | 05:16 AM
wr1970's Avatar
Yes that is what they were attempting.
Old Oct 20, 2019 | 05:22 AM
wr1970's Avatar
I have seen brazed and welded in the water jacket area. That was many years ago when people were to poor to change engines and they would doing anything to get a few more miles out of them. 😂
Old Oct 20, 2019 | 06:26 AM
exotec's Avatar
Olds Omega
so, I did some search and found this: https://streettechmag.com/2015/03/23/block-repair/
sure looks different
Old Oct 20, 2019 | 08:21 AM
Not my malfunction but I do still have a 324 sitting in the shed with a 11 inch crack going from petcock to the last freeze plug. I drove it home about 70 miles with a couple cans of Bars-Leak and a 5 gallon Jerry can of extra water... We call that a parts engine now..... Tedd
Old Oct 20, 2019 | 09:49 AM
wr1970's Avatar
Yeah I think so too. Heck i would weld it up and use that engine some more.
alburk
Sep 16, 2019 03:30 PM
scrappie
Sep 6, 2019 05:41 PM
rktolds
Aug 10, 2017 05:28 PM
j808702
Jul 9, 2017 06:26 PM
kevdog442
Jan 3, 2009 03:21 PM
