Pertronix module breaker plate problem.
Old Aug 10, 2019 | 02:22 PM
Destructor's Avatar
Today I installed my Pertronix module but there is a tang from a previous ground wire spot welded to the plate. It can not mount to the original points position. But it can be mounted in another position counter clockwise. I'm wondering if the other position on the plate is for a duel point set and how many degrees I could be off. It doesn't seem to be 180 degrees off. Or, maybe the plate is manufactured for different points positions for different divisions or years. Distributor is a reman from maybe 12 years ago. The module perfectly dropped into the "other position".
Old Aug 10, 2019 | 05:54 PM
Destructor's Avatar
No problem shifting the mounting position of the module. I got the engine started after a bit of fiddling with timing. Just need to fine tune. Interesting that the distributor plate has mountings for two different points locations.
Old Aug 11, 2019 | 07:08 AM
RetroRanger's Avatar
72 Olds CS
I don't know for sure but you said it's a reman dizzy so maybe there is a universal plate that encompasses early and late distributors? That's just a guess! Glad you got it going I would imagine the vacuum can may now be in a better or worse spot depending on how the dizzy was stabbed.
Old Aug 11, 2019 | 09:19 AM
Destructor's Avatar
I still have the original distributor somewhere but one of the points screw holes is stripped. I'll take a look at it. Maybe I'll rebuild it if I can find another distributor plate.
Took it for a quick ride today, runs smoother and stronger than with points that I didn't clean up after it's winter slumber. I only tuned it by ear. When I get time I'll dial it in better, get a sticker then take it for a good run. I got sick of cleaning and/or changing points every spring.
Old Aug 11, 2019 | 03:25 PM
72 Olds CS
Yeah I have an HEI in mine to reduce maintenance.
Old Aug 18, 2019 | 03:13 AM
markmag's Avatar
Points
Hi I have a petronix ignition in my 1963 Olds super 88.smoothed her out so nice!. Then a Elderbrock carb,did the rest...mark
Old Aug 19, 2019 | 06:42 AM
Kensey's Avatar
Do yourself a favor, keep a set of points in your glovebox.
bob p
Apr 2, 2015 12:18 PM
jRoofgunner
Dec 1, 2014 05:51 PM
72Burning$$
Mar 28, 2014 04:43 PM
Moses
Jun 11, 2011 12:58 AM
Moses
Jun 10, 2011 09:37 AM
