1968 ho metal dashboard.
Old Jul 9, 2019 | 07:54 AM
wr1970's Avatar
Hello need some advice. The speaker area of the dashboard is it flat black beyond dashpad? Is the lower dash semi gloss . Are the pin stripes from side to side painted all the way. Pictures advice welcomed.
Last edited by wr1970; Jul 9, 2019 at 07:57 AM. Reason: Title has typo error should eat metal.
Old Jul 9, 2019 | 09:35 AM
83hurstguy's Avatar
Here's what I think I know: Top of dash/speaker area is flat and might be kind of textured to limit glare. Front of dash is a semi-gloss, but I couldn't give you a good reference paint to replicate the correct sheen. The pinstripes are tape, they go down the sides of the dash, curve, then run across with a break at the steering column.
Old Jul 9, 2019 | 11:40 AM
allyolds68's Avatar
I used SEM Landua Black on the whole dash and it was a perfect match to the bottom. With the top in direct sunlight I don't know how you could ever tell what it should have been. This is the first time I've even heard that the top of the dash was a different finish than the bottom.
Old Jul 9, 2019 | 11:45 AM
allyolds68's Avatar
Original dash pin stripe pics from my 68. It's very unlikely my car had a dash restoration before I got it
Old Jul 9, 2019 | 12:50 PM
83hurstguy's Avatar
The PIM indicates different paints for upper / lower instrument panel... see attached snip. If you trace that back a few pages, the codes match to flat upper, semi-gloss lower.
Old Jul 9, 2019 | 01:27 PM
wr1970's Avatar
Thanks was sure almost that I was looking at a factory dash. Pictures were great help and the information snip.
sjay1989
Mar 2, 2019 03:38 PM
1970greensupreme
Jan 30, 2017 06:41 AM
jesseb
Paint
Apr 18, 2012 09:48 AM
bonezarally
Sep 19, 2010 09:26 AM
mike14_07
Jul 14, 2009 07:52 AM
