The Best Spark plugs for 403 6.6 L
Old Jul 1, 2019 | 11:19 AM
Queenzflip's Avatar
I hope this isn’t a stupid Question, but I’m going to jump out the window, what is the best spark blush for a 406 6.6 (Oldsmobile). Please explain which ones are the best and why.
Old Jul 1, 2019 | 01:53 PM
There is really no right or wrong answer here, its personal preference and performance application if you mod'd the engine.
Old Jul 1, 2019 | 03:09 PM
Sugar Bear's Avatar
Stock motor? Stock ignition? What is it in, year make, model?
Old Jul 1, 2019 | 04:10 PM
Queenzflip's Avatar
# on the engine
To be honest idk, this is all new to me, this is why I come to this forum to learn. i couldn't find the year of the engine, the last forum they told me to look under the first spark plug, I didn't see it, all i know its a 403 6.6L with a X on it. my car is a 1955 Oldsmobile
Old Jul 1, 2019 | 04:11 PM
Queenzflip's Avatar
thanks for that, idk if the engine was Modified
Old Jul 1, 2019 | 04:50 PM
The 403 engine was produced for three years from 1977 to 1979, and they were all essentially the same. Can you post a photo of the distributor to show if it's a points style or HEI? I don't think that really changes the spark plug choice, it just lets us know what you have.
Any plug for an Olds engine would work (except the .060 and .080 gapped ones as those gaps are way too wide); knowing your application just helps get the heat range right.
Old Jul 1, 2019 | 05:22 PM
Queenzflip's Avatar
Disturber Cap
Old Jul 1, 2019 | 06:09 PM
Any of the plugs listed in this link will work, I'd gap them at .045 instead of .060:
https://www.rockauto.com/en/catalog/...park+plug,7212
Old Jul 1, 2019 | 06:10 PM
Burd's Avatar
I’m so used to seeing the 403 in the trans am. What Olds cars got these engines?
Old Jul 1, 2019 | 06:44 PM
Sugar Bear's Avatar
Distributor looks to be a stock GM HEI, that's good. They are reliable and easy to get parts for.
What plugs are in it now and how do they look? The current plugs may be the answer for the heat range, convert that plug to an AC Delco plug and gap at.045 as suggested.
Good luck!!!
Old Jul 2, 2019 | 06:26 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
NGK XR45 gapped to .045" on a stock 403, XR5 is the next coldest plug. I have had 0 issues on my 9 to 1 350. I have found them smoother running over AC Delco or Autolite Chinese plugs.
Old Jul 3, 2019 | 07:15 AM
Queenzflip's Avatar
why would you gap them at .045 instead of .060?
Old Jul 3, 2019 | 08:32 AM
The larger the gap the more stress on the coil. .045 is more than sufficient to fire a plug hot enough to ignite the fuel load.
Old Jul 3, 2019 | 08:58 AM
The .060" and .080" gaps were used on smog era engines with EGR (maybe AIR also?) and, from what has been posted here, that wide gap was needed to get the very lean mixture to ignite. There's no reason to use that wide of a gap on your setup.
Napoleon1991
Jul 20, 2016 08:16 PM
bobfo1
Jul 17, 2014 06:06 PM
72cutlassdog
Aug 13, 2013 12:34 PM
MaxDog
Jul 7, 2012 09:13 AM
72442clone
Jul 15, 2011 11:53 AM
