spark plugs
Old Aug 8, 2013 | 07:48 AM
72cutlassdog's Avatar
spark plugs
I read a lot of threads about the best plugs for 455 engines.
What are the best for 350's? This is a two part question. If I want performance which ones are the best? If I want longevity which ones are the best? Also who has the best wire set? My car is a 72 cs. Thanks!
Old Aug 8, 2013 | 08:15 AM
To answer your question for a stock engine, then stock and ...stock. For performance engines it's a little more complicated, everyone has their own favorite brand and heat ranges are based on combustion characteristics. For wire sets I like Taylor Spiro-pro.
Old Aug 13, 2013 | 12:24 PM
I am just talking about a stock engine. What I meant by performance was a plug that gives more boost.
Old Aug 13, 2013 | 12:30 PM
Plugs don't give boost, they work or they don't. Higher voltage spark is gained by a performance oriented ignition system.
Old Aug 13, 2013 | 12:34 PM
pogo69's Avatar
morgan
i dont think its that easy to answer... depends a lot on type of fuel used also...stock plugs should be fine, i have always used A/C
bob p
Apr 10, 2015 01:55 PM
maquis1431
Sep 27, 2008 10:42 AM
65Delta88
Sep 11, 2008 10:13 AM
KQQLCAT
May 6, 2008 08:18 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
