What exactly is a O axel?
I have heard and read a lot about these axels. What exactly makes a O axel one? Is is the fact that they are bolted to the tube ends instead of being held in by a c clip like a Chevy? Matt
In the crazy days of 65-70 when the GM lines were consolidating common parts, there were lots of oddities. The O axle is one of them. Olds designed it before the now-common c-clip 10 bolt. But, since the consolidation was happening, there are still a lot of similarities.
The external critical dimensions (mount points, tube ends, flange ends, pinion location) are all the same across a bunch of the rears. The O can be thought of a hybrid between the 12 bolt and the 10 bolt with bolt-in axles. It uses unique (or at least very seldomly used otherwise) bearings, has strength somewhere between the 12 bolt and 10 bolt, and uses bolt-in axles. The O rear shares very few parts with any other rear end.
Olds switched to the bolt-in 10 bolt which shares a lot of parts with the c-clip except the axles are bolt-in, so the axles and axle bearings are different. It's a better rear than the c-clip but the manufacturing costs aren't as high as the O rear since most of the parts are common.
http://wildaboutcarsonline.com/membe..._Diff_1-12.pdf
HitTheHole
Drivetrain/Differentials
February 4th, 2021 10:46 AM
shockrebuild
September 26th, 2017 08:10 PM
shaks 442 clone
May 14th, 2008 04:01 PM
