Power Steering Pump Question
Old May 13, 2019 | 09:55 AM
VikingBlue's Avatar
Car sat for 6 months. Started, started to move but could barely turn wheels. No squealing noise from pump, but a major bi*ch to turn. Checked fluid level and was empty, then saw where it leaked out.
Added fluid, restarted, then an awful noise similar to cats fighting even without turning the steering wheel....and adding fluid didn't make turning the wheel any easier. Do you need to turn the wheels back and forth for a while for newly added fluid to get into the lines ?
Or is something else most likely the problem ? (pump or belt)
Old May 13, 2019 | 10:27 AM
You still have air in the system. Let it run for a while. Even better, jack the front end to get weight off the tires and turn the wheel lock-to-lock a few times. Expect to top off the reservoir once the foam subsides.
Old May 13, 2019 | 01:14 PM
Weezer's Avatar
Jeff
And, if what Joe mentions does not work... you might have a stuck flow control valve. Or... you might have a problem like mine, where I had a stuck valve, then bled the system by turning several times lock to lock, and STILL no power steering. Good luck! It's probably just air in the system like Joe said. I have read that you're supposed to do the lock to lock turns with the engine off, though.
Old May 13, 2019 | 05:01 PM
From my 1971 CSM:
(1) With wheels turned all the way to the left, add PS fluid to "Cold" mark on dipstick;
(2) Start engine, and running at fast idle, recheck fluid level. Add fluid if necessary to "Cold" mark on dipstick; (Remember, the wheels are still turned to the left)
(3) Bleed system by turning wheels from side to side WITHOUT hitting stops. Maintain fluid level just above internal pump casting. Fluid w/ air in it will have a light tan or red appearance. The air must be eliminated from fluid before normal steering action can be obtained;
(4) Return wheels to center position and continue to run engine for two or three minutes, then shut engine off:
(5) Road test to make sure free of noise;
(6) Recheck fluid level as in above steps making sure fluid is at "hot" mark on dipstick after the system has stabilized at its normal operating temperature.
Old May 14, 2019 | 06:42 AM
Weezer's Avatar
Jeff
I'm going to give it another shot on my '64 using the steps you provide, Norm. Thanks!
My2nd 69 442
Apr 16, 2018 07:17 PM
72hardtop
Mar 21, 2015 10:24 AM
Jetstar 88
Apr 17, 2012 04:25 PM
Stevec
Suspension & Handling
Jul 15, 2011 02:42 PM
oldjunkster
Nov 10, 2010 07:52 AM
