Speedo cable and sheathing help needed - '70 Cutlass
Old May 10, 2019 | 11:00 AM
BSiegPaint's Avatar
I got a replacement speedo cable from Inline/Motorcity as it advertised being "correct" with the cable and the added sheathing on the outside. Their photos show this pretty clearly. However what I got was a cable and a length of rubber hose. There is no way to install this hose over the cable without removing one of the press fit cable ends. I've been waiting quite some time for a response from Inline, but I'm to the point where I need to get this installed. Should I just slice the tubing and install the cable, taping or caulking the tubing shut, or is there a way to remove and replace the cable end such that I can slide the cable into the hose as it was supposed to be in the first place?
Old May 10, 2019 | 11:40 AM
alain's Avatar
How about vasoline on the small end gently pulling it through?
Just an idea.
Alain
Old May 10, 2019 | 11:47 AM
BSiegPaint's Avatar
Just an idea.
Alain
I should have taken a pic of the hose I.D. and the smaller end that clips to the speedo back. They're way different in size, and for the 3 feet of length, there's no way to squeeze it through. One end of the cab;e has to come off to keep the hose in one solid piece... This reminds me of the Mad Magazine "ship model kit" that was a block of wood and a knife - "carve away everything that doesn't look like the ship picture"... They took a picture of one that was made that way - maybe some instructions from them would help. I suppose it's possible that I'm supposed to split the hose the full length and tape it back together. But if that were the case, I would have bought the $10 cable and a $2 piece of rubber hose to do it. I paid extra to get the part they advertised and pictured....
Old May 10, 2019 | 12:00 PM
alain's Avatar
Ok slice the hose about 2 to 3 inch vasoline and twist and turn and pull maybe.
No more ideas after this.
Alain
Old May 10, 2019 | 12:22 PM
BSiegPaint's Avatar
Alain
I'll stare at it for a while when I get home this evening and see if it looks remotely possible ))
Old May 10, 2019 | 02:40 PM
From the picture it looks like you slit the hose open on one side, slip the cable in the slit and use electrical tape to close the gap in spots.
Old May 10, 2019 | 07:14 PM
BSiegPaint's Avatar
Yeah, I see what you're seeing. I'm feeling worse about this purchase as the hours go by lol. OK, I'm going with that - not a lot else I can do. They didn't send me any lube, either, so I'll have to go find that tomorrow before this goes in. I'll get out the assembly manual as well and see what I can see. Thanks
Old May 11, 2019 | 06:09 AM
VC455's Avatar
Barely Registered
Originally Posted by BSiegPaint
...I've been waiting quite some time for a response from Inline...
Bob, I've only bought directly from Inline, and every order seemed to have some kind of problem.
To their credit, they always answered the phone and eventually worked out the problems. Try calling again.
Old May 14, 2019 | 01:02 PM
BSiegPaint's Avatar
Follow-up - they DID get back to me and let me know that oldcutlass was right - the hose has to be slit the full length and the cable inserted inside, taping it closed. They also told me that the missing cable lube (shown in their picture/auction) wasn't supplied anymore, and they were "changing their picture". Ah. Seems like you should change your price since I paid for lube you didn't deliver...
jaunty75
Mar 5, 2018 02:42 PM
VI Cutty
May 14, 2017 09:25 PM
Bfg
Jan 16, 2017 04:38 AM
Nighthawk
Jul 27, 2013 09:49 AM
1972cutsupreme
Brakes/Hydraulic Systems
Oct 1, 2012 01:12 PM
