Wipers do what they want when they want
Old May 13th, 2019, 04:52 AM
Jimbo120's Avatar
Does anyone have any ideas on this? Before I put the car away for the winter, on the last drive, the wipers turned themselves on. Took a swipe and stopped. Took another swipe and stopped in the middle. I pulled out the wiper switch and it was worn out. No locking positions for each speed or even off. Figured this was the problem. Replaced the switch when the weather broke thinking this was the problem. Apparently not. Wipers still do what they want when they want to. I have no control. Turning the switch on and off doesn't seem matter. They will be fine for a couple of miles then all of a sudden they go on. Not running like you would have them on for rain. Very jerky motion. Does this sound like a motor problem or a mis-wire somewhere?
Jimbo120 is offline
Old May 13th, 2019, 06:01 AM
FN723's Avatar
A switch just completes the circuit giving the motor power. It sounds like there is a raw wire somewhere giving the motor power more or less bypassing the switch. Probably when you hit a bump just right it makes connection.
FN723 is offline
Old May 13th, 2019, 06:33 AM
Well, for starters the mind reading thing isn't working, so telling us the year, model, single or dual speed, pulse or not would help.
Note that starting with the early 1960s, the circuit is NOT a simple switch that provides power. There is a hold-in relay that keeps the motor running after you turn it off to park the wiper blades. This relay can stick, among other failure modes. There is also a cam in the motor that actuates the park contacts. Read the Chassis Service Manual section that describes the wipers and troubleshooting.
joe_padavano is offline
Old May 13th, 2019, 07:02 AM
Jimbo120's Avatar
1967 442, 2 Speed. No pulse
Jimbo120 is offline
Old May 13th, 2019, 03:17 PM
Yellowstatue's Avatar
Also sounds like a lot of kids.
Yellowstatue is offline
Old May 13th, 2019, 06:43 PM
No park, either.
Koda is offline
Old August 20th, 2019, 05:54 PM
Jimbo120's Avatar
I never responded with what I found to be the problem. In case anyone was wondering. On the wiper motor, bottom screw was loose making an intermittent ground. Tightened, problem gone.
Jimbo120 is offline
Old August 21st, 2019, 11:41 AM
Lucky bugger! TY for the follow-up.
Vintage Chief is offline
Old August 21st, 2019, 04:00 PM
Rocket Renegade!
Yes, thanks for letting us know. That'll probably help somebody out in the future.
BangScreech4-4-2 is online now
young olds
March 21st, 2020 07:16 AM
drkearnel
August 17th, 2018 02:53 PM
atkinsom
October 16th, 2014 07:07 PM
vitaleyes
November 14th, 2012 07:43 AM
My442
July 29th, 2010 04:14 PM
Quick Reply: Wipers do what they want when they want
