Ow vin stamping photographs
I found a '70 W30 with an OW transmission. I posted photographs of the OW tag and rivet and the tag looks right.
I've asked the seller for a photograph of the number stamped into the OW transmission. The seller said that he tried, but can't get a photograph of the VIN stamp. He took off the shift linkage, used a mirror and can't get a photograph. He read the numbers off the OW and they tie into the VIN number of the car.
He's willing to provide photographs of the stamp, but can't get a clear photograph. Any ideas how to photograph the VIN stamp on the OW??
Thank you and Happy New Year!
Number on OW read off to the seller.
Lansing car. Build date 06D.
Thanks for responding. I will pass on your idea and we'll see how the light and angle work. I'll keep you informed. Thanks again.
I asked him, as described above, to either try taking the photograph from the side or without the flash.
I believe him to be sincere. I want to ensure that he wasn't deceived with a restamp. He's owned the car fifteen (15) years.
He removed the shift linkage and also Disconnected the speedometer cable and couldn't get a decent photograph. When you described removing the floor shift cable, that would move with the floor linkage disconnected??
THanks RetroRanger!! I'll pass this on to the seller. Sounds like this will work. I'll keep you informed.
I'm being cautious. I want to see the stamp on the transmission to verify that it is the original stamp and ties into the VIN number. Although I believe the seller to be sincere, " Trust but verify." Ronald Reagan.
I had posted photographs of the engine compartment, frame stamp and the underside in an earlier post.
That carburetor would not have come on that car. The date is much to old. At least I have not seen that late of a car with that old of a carburetor. It could have happened but very unlikely. I would like to see another picture of the carb numbers from another angle. You may want to post the carb number picture on the Re-stamp thread and get other opinions of the stamping. I am not sure on this one from that picture. Looks like a really nice car though.
Thank you for your information on the carburetor and your compliment on the car. I am most concerned about the OW stamp to confirm that the transmission is an OW and hasn't been restamped or altered.
If not, I may consider the car a really nice, solid 442 convertible.
This is a convertible, correct? Wy does it have the 455 fender braces? Windshield washer bottle mounted on wrong fender. Looks like it has a radiator overflow. May have used a couple cars to make one, or just ove restored.
olds53rocket
December 22nd, 2006 05:46 PM
