1972 cutlass supreme measurement?
Old Dec 24, 2018 | 11:35 AM
Josh Pawnell's Avatar
Jcpwelds
Is there any one with a 1972 Oldsmobile cutlass supreme that can take a measurement for me on there car. I'm making a patch panel an need it . Thank you
Old Dec 24, 2018 | 02:10 PM
Jcpwelds
Anyone?
Old Dec 24, 2018 | 02:33 PM
Where is the patch being applied? There are replacement patch panels available for the 70-72 Cutlass. Fenders are the same for all the A body line in those years, so the patch panels also are. If it's a quarter panel, there are also reproduced quarter panel skins that aren't terribly expensive.
Old Dec 24, 2018 | 03:00 PM
Jcpwelds
it's that section right there I found both sides were nothing but bondo, so I have made some replacement patches I just want to know the length of the section pointed out by the arrow be for I install, to make sure it's correct.
Old Dec 24, 2018 | 03:03 PM
Jcpwelds
This is where im at now just like to do any fine tuning before installing
Old Dec 24, 2018 | 05:43 PM
70W-32's Avatar
have ou removed the rear window? that area includes the window channel, which is probably rotted away too.
Old Dec 25, 2018 | 07:01 AM
Jcpwelds
Yeah I removed the window , trunk filler panel was rotted an some of the structure beneath it . All that is fixed, just gotta put the c pillar patches in first after I get the measurement
Old Dec 25, 2018 | 09:29 AM
cdrod's Avatar
Rodney
Can't you just measure the opposite side or are both sides rotten?
Old Dec 25, 2018 | 09:43 AM
Jcpwelds
Both sides were rotted, whoever had it before was talented with bondo clearly. I tried looking at pictures but it's still a guess as to the length.
Old Dec 25, 2018 | 12:42 PM
11971four4two's Avatar
MOTORHEAD
measurement? Does this help
Old Dec 25, 2018 | 01:23 PM
Jcpwelds
Hell yeah , what's that bout three inches, That is exactly what i needed thank you so much
Old Dec 25, 2018 | 02:21 PM
MOTORHEAD
2 3/4 or so
have a merry christmas
Chuxter
May 22, 2014 12:58 PM
blackngold442
Jan 28, 2014 04:31 PM
Nighthawk
Body work
Nov 2, 2013 07:11 AM
blackngold442
May 27, 2013 11:26 AM
andrew.minarick1
Jan 12, 2013 07:17 PM
