1972 442 455 4 barrel Carburetor Part Number
Old November 5th, 2018, 07:51 PM
twilightblue28A's Avatar
I know you've been asked this one-thousand times. Is the correct carburetor PN 7042251? Date code 10:12 equals what build date for the carburetor?
Also, I want to verify the correct side stripes. Are the side stripes the same as the '70 442 or did Olds change the number of side stripes to three? One larger stripe approximately 3/8"in the center, surrounded by one smaller stripe above and below the center stripe? A drawing will be helpful.
Good news: No W-30 side stripes!!!
twilightblue28A is offline
Old November 5th, 2018, 08:04 PM
MOTORHEAD
11971four4two's Avatar
7042953 is the one you would like to have
11971four4two is online now
Old November 5th, 2018, 08:06 PM
MOTORHEAD
stripes are not the same as 1970
I did post pictures before
Old November 5th, 2018, 09:00 PM
thank you. The stripes for '72 442 are posted where and I will look for the drawing.
Regarding the carburetor 7042953. The current carburetor 7042251 date coded 10:12 ties into the 101st day. Roughly March, 1972. The car was built May 1972. So that sounds correct. The current carburetor 7042251 is for what engine in 1972?
​​​​​​Thank you
Old November 5th, 2018, 09:40 PM
MOTORHEAD
Go search the site
Old November 5th, 2018, 09:48 PM
Go search the site
i searched for both questions asked. I can not determine if '72 442's have three stripes. I looked into Phoenix Graphics .
Regarding the carburetor, 7042251 is on the car with the appropriate Julian date code corresponding to the cars build date. I checked your posts and you have a 455 4 barrel carburetor 7042251 for sale.
I asked for help. Thank you for your kindness .
Old November 5th, 2018, 09:54 PM
MOTORHEAD
Yes 72 has 3 stripes
as does 1971
pay no mind to 251 carb
Old November 5th, 2018, 10:06 PM
as does 1971
Thank you for the stripe help. Pay no mind to the prior 251 carburetor being incorrect for the '72 455 4 barrel 442 or that it is the correct carburetor for the '72 455 4 barrel 442. To be clear, this is a U code not an x code W-30 .I appreciate your help clarifying the correct carburetor for this car. Thanks again.
Old November 6th, 2018, 05:24 AM
dc2x4drvr's Avatar
My painter followed the ‘71 assembly manual to layout the “442” stripes. I tried to upload pics of an original ‘71 442 fender, but no bueno, pm your email, if you need the pics. Glad you’re staying original!
dc2x4drvr is offline
Old November 6th, 2018, 05:50 AM
That is the correct carb for the 1972 455 U codes. 101st day Julian Code is April 10, 1972 - same day as my car was built.
Allan R is offline
Old November 6th, 2018, 05:58 AM
Thank you!!
PM Sent
Old November 6th, 2018, 06:01 AM
Great. Thanks for clarifying the carburetor on the car is correct and that the carburetor was built before the car.
I appreciate your clarification and your help.
Old November 6th, 2018, 06:16 AM
This is an unmolested 4700 mile 72 442. If you want Hi resolution pics, send me your email via PM
Allan R is offline
Old November 6th, 2018, 06:17 AM
Original factory stripes
Allan R is offline
Old November 6th, 2018, 12:00 PM
EDIT: Correction - Carb for 455 should be 7043251, not 7042251. The 251 made me think it was 3251.
Allan R is offline
Old November 6th, 2018, 02:41 PM
Rocketbrian's Avatar
What a confusing thread, just as 7042251 was correctly identified as the correct carb number for a regular 72 455, we are now revising it to 7043251? The fourth digit is for the model year, hence 7043251 is for a 73 regular 455 carb.
To further clarify, a 70 350 would be 7040250, a 455 would be 7040251. A 71 350, 7041250 and a 71 455 7041251 and so on. 70 and 71 442s and W30s have their own numbers as do the 72 X code W30s. You have the correct carb at 7042251.
Rocketbrian is offline
Old November 7th, 2018, 05:34 AM
Originally Posted by Rocketbrian
What a confusing thread, just as 7042251 was correctly identified as the correct carb number for a regular 72 455, we are now revising it to 7043251? .......... You have the correct carb at 7042251.
Hey Brian, yeah I don't know what came over me. I know the difference between 7042250 and 7042251, and 7043251. For some strange reason I can't explain I posted that last one. Clearly the 7042251 is the correct carb.
To Harry - I apologize for the confusion that was generated.
Allan R is offline
Old November 7th, 2018, 08:08 PM
Not a problem. We have the number. We all make mistakes.
Thanks,
Harry
Old November 8th, 2018, 06:34 AM
Indy Guy's Avatar
2251 should be correct carb. I've had that carb on all my 72 H/O cars, which are "U" code cars.
Indy Guy is offline
pfergy600
December 22nd, 2014 04:57 AM
JR442
Paint
May 31st, 2013 10:13 PM
RickH
April 6th, 2012 07:36 PM
theoldsrocket
Paint
December 5th, 2010 05:20 PM
KZ442
November 8th, 2010 10:57 PM
Quick Reply: 1972 442 455 4 barrel Carburetor Part Number
