Cable Selection???
Old September 3rd, 2018, 02:30 PM
rickbmac's Avatar
Cable Selection???
Unsure if this is correct location for question? If not; please direct me to correct area. Built engine during restoration 350 Rocket/TH350 transmission with Dualgate shifter. Upgraded to Holley 6150 (mechanical secondary). Now at point that I require throttle and detent cables. I assume that the stock detent cable to pedal is sufficient. My concern is best choice for throttle cable? Please advise.
Last edited by rickbmac; September 4th, 2018 at 03:43 AM. Reason: Wrong exclamation
rickbmac is offline
Old September 3rd, 2018, 02:55 PM
Yes the stock cable would work assuming you have the correct pedal.
oldcutlass is offline
Old September 3rd, 2018, 03:46 PM
rickbmac's Avatar
Yes, stock pedal. I assume that I will just need an adapter from stock cable to Holley carb?
rickbmac is offline
Old September 3rd, 2018, 03:47 PM
You may be able to make your stock linkage work, just make sure the pedal opens the carb all the way.
Old September 3rd, 2018, 05:50 PM
rickbmac's Avatar
Cable selection???
Thank you Eric. I am unsure what a throttle cable question has to do with my transmission. On my smart phone and lost location of post for a bit.
rickbmac is offline
Old September 3rd, 2018, 06:11 PM
I moved it to General Discussion. Initially I thought we were talking about the detent cable. If the stock setup does not work there are many aftermarket available for a Chevy to work of the holly linkage. Let us know what works.
Old September 4th, 2018, 03:37 AM
rickbmac's Avatar
Will do
Will do, thanks Eric
rickbmac is offline
Old September 4th, 2018, 06:17 AM
I am doing a similar thing on my 73 Ford van putting a Holley on it. Holley makes carbs that can handle a wide variety of stuff, and there are all sorts of accessory kits for specific applications. You may need a few parts.
Koda is offline
Cman7713
September 20th, 2017 10:54 AM
sammy
September 8th, 2015 08:31 PM
Crockett 999
April 27th, 2015 07:57 AM
archerbob
September 12th, 2011 01:29 PM
rocketscientist
April 29th, 2010 08:13 PM
Quick Reply: Cable Selection???
