Rear manifold water nipple
No. My original 72 350 did not have one. That was with a 2 core radiator too. But I do run one now that a 455 is in its place. Because... I picked up a edelbrock o4b which had a non stock nipple that had a washer welded into it. Seemed a good idea so I left it. You know, why not keep more flow into the radiator. The hole in the middle of the washer is about a 3/16 of a inch diameter. I also am running a 4 core radiator now too. Tom
I drilled out the nipple in my Vista and then discovered that the heater core made a hellova lotta racket with so much coolant rushing through it. So I installed a gate valve in the hose to restrict the flow...heater ON.
