Rear manifold water nipple
Old Jul 3, 2018 | 02:18 PM
woodie582's Avatar
Non A/C car, 350. Is the restricted nipple required?
Old Jul 3, 2018 | 02:45 PM
Yes.
Old Jul 3, 2018 | 02:47 PM
tangokilo's Avatar
No. My original 72 350 did not have one. That was with a 2 core radiator too. But I do run one now that a 455 is in its place. Because... I picked up a edelbrock o4b which had a non stock nipple that had a washer welded into it. Seemed a good idea so I left it. You know, why not keep more flow into the radiator. The hole in the middle of the washer is about a 3/16 of a inch diameter. I also am running a 4 core radiator now too. Tom
Old Jul 3, 2018 | 03:20 PM
woodie582's Avatar
Looks like I'll put the proper one in then.
Old Jul 3, 2018 | 06:57 PM
I blew out about 4 heater cores over a period of 15 or so years before I realized the restrictor is there to prevent that exact situation.
So yes, the restrictor is required.
Old Jul 4, 2018 | 05:00 PM
woodie582's Avatar
Good to know, I have one on order. Wondering if it does indeed also help with cooling.
Old Jul 4, 2018 | 06:07 PM
Yellowstatue's Avatar
I drilled out the nipple in my Vista and then discovered that the heater core made a hellova lotta racket with so much coolant rushing through it. So I installed a gate valve in the hose to restrict the flow...heater ON.
David DeCan
May 9, 2019 09:23 PM
denf221
Oct 27, 2017 09:03 AM
Gary M
Oct 18, 2015 03:45 PM
jjokrm
Jan 24, 2013 01:31 AM
cutlass47
Mar 13, 2009 05:50 PM
