Tip on shipping supplies
Old May 21st, 2018, 01:00 PM
2blu442's Avatar
Hi All
I wanted to share an idea that I've found to be helpful. Since we're in an election year we'll see a lot of corrugated plastic signs for different candidates. After the election, if someone doesn't plan to run again or if the appearance of the sign isn't good they'll be tossed. I'm a bit of a political junkie and have contacts within the local party. When they were cleaning out the old signs I had a chance to snag some... like a lifetime supply! I think the big signs are 4'X8' and I have wrapped fenders, quarter panels, and just large packages with them. Then the smaller ones I've used to line cardboard boxes for heavy items like rear end carriers or brake parts. They are much stronger than cardboard but will easily cut with a razor knife. So for those of you who have or plan to ship large or heavy items you might contact your local campaign offices to see if they have any signs they're throwing out.
2blu442 is offline
Old May 21st, 2018, 01:40 PM
oldspackrat's Avatar
Great tip John! I hoard boxes & shipping tubes & I'll have to add these to the mix.
There is a local junkyard that buys & sells parts & they will give you all the used bubble wrap you want. I go there on occasion & come home with 5-7 trash bags full of the stuff. I've had to have saved thousands by doing stuff like that.
oldspackrat is offline
Old May 21st, 2018, 02:04 PM
Frank Ignachuck
ignachuck's Avatar
Great idea!! After four terms, I retired and have a bunch of these left over!
ignachuck is offline
Old May 21st, 2018, 03:33 PM
Ozzie's Avatar
Good suggestions. I don't know if they are considered "archival" or not, but I've also used them to mount photographic prints. Any application should be better than sending them to the land fill.
Ozzie is offline
Old May 21st, 2018, 04:53 PM
jensenracing77's Avatar
Good idea! I am lucky. I have all the boxes and packing I could ever want from work. I only have to buy tape.
jensenracing77 is offline
Old May 21st, 2018, 06:31 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Great bird cage or garage floor liner too, same as the local newspaper cept its waterproof!
droldsmorland is offline
Nilsson
May 18th, 2009 09:20 AM
gearheads78
February 14th, 2009 10:06 AM
Dapapadon
February 2nd, 2009 11:31 AM
csouth
December 15th, 2008 04:07 AM
The Pope
July 11th, 2007 06:13 AM
Quick Reply: Tip on shipping supplies
