1968 442 Vaccum canister for trunk release
Old Jan 8, 2018 | 03:44 PM
sbasinger@hotmail.com's Avatar
When did they stop using a metal canisters for vacuum trunk release in a cutlass/442. Are the parts for a 1967 and 1968 the same? On the metal canister the nipple area is loose....is it supposed to be? Can it be tightened? Will it do any harm to put air into it to test it?
Old Jan 8, 2018 | 07:07 PM
rcorrigan5's Avatar
Randy C.
I believe the last year for the tuna cans was 1968. I picked a few of them off of '68 A-bodies in junk yards years ago. My '69 has the plastic reservoir and I'm pretty sure that's the first model year they started using them.
The nipple on the metal cannister shouldn't be loose - that could be a cause for loss of vacuum.
Others can answer the rest of the questions.
Randy C.
Old Jan 9, 2018 | 06:39 AM
oldspackrat's Avatar
It should cause no (more) harm to test the vacuum can. If it does leak one solution, besides getting a good one, is use a small dab of rubberized caulk? It comes in white & black & would be hard to notice once repaired. Like Randy said, I "think" the last year for the metal can was '68? They also used the same can for AC cars & on big cars & on other models & years of G.M. cars with AC.
Old Jan 9, 2018 | 07:57 AM
lemoldsnut's Avatar
I have had several 65 Olds cars with the metal can and never seen a metal one on a 66 or newer. I have several of either if you end up needing one.
Larry
lemoldsnut@aol.com
541-815-4363
Old Jan 10, 2018 | 08:42 AM
Bfg's Avatar
Bfg
I have a 65 442 with A/C and a vacuum trunk opener with both plastic tanks. Lansing built car.
Old Jan 10, 2018 | 08:45 AM
Bfg's Avatar
Bfg
I also parted a 67 442 with the metal tank, that was a Freemont built car. Maybe it was determined where it was built?
Old Jan 10, 2018 | 11:34 AM
rcorrigan5's Avatar
Randy C.
Back in the 80s, the first vacuum-operated trunk release I from a junk yard car came from a '68 Cutlass and it had the metal "tuna fish can" vacuum reservoir. I don't know where that car was built.
Starting with model year '69, I've never seen a GM car with the firewall-mounted vacuum reservoir. However, the power-door-lock vacuum canister in '69 was still a metal can, albeit much larger than the firewall-mounted metal vacuum reservoirs.
Randy C.
Old Jan 11, 2018 | 12:29 PM
Indy_68_S's Avatar
Randy C.
My '68 Cutlass built 04/30/1968 in Lansing has the plastic vac tank (on the firewall) for the trunk release, not the metal 'tuna can'. I'm positive it's original due to it having undercoat splatter consistent with the surrounding area.
Maybe switchover was late '68 production ?
Old Jan 11, 2018 | 07:03 PM
I have a very original and dirty plastic tank on the firewall of my 67 for AC controls. I believe the can is the same part number as the vacuum trunk can.
Chuck_66
Jan 11, 2012 02:03 AM
warrior71
Feb 5, 2009 03:20 PM
KQQLCAT
Oct 20, 2008 07:21 AM
KQQLCAT
Sep 2, 2008 10:12 AM
72CUTTY
Brakes/Hydraulic Systems
Jun 25, 2008 05:21 PM
