1972 Cutlass Supreme convertible w/455 production numbers
Old December 16th, 2017, 12:53 PM
hurst68olds's Avatar
My uncle just bought a well optioned '72 Cutlass Supreme convertible including factory 455 & automatic.
any thoughts on 455 'vert production numbers? more common with or without 442?
prior '72 numbers thread:
https://classicoldsmobile.com/forums...rs-1972-a.html
hurst68olds is offline
Old December 16th, 2017, 07:10 PM
vette442's Avatar
If your uncle is Paul, I've had a bunch of texts back and forth with him over the past couple days. The numbers I gave him are unpublished numbers from the GM archives so they're as good as we're likely to ever get.
Thru June 1972 with a few weeks of production left, 130,784 Supreme hardtops and convertibles (4200 series) were built. 3015 of these cars had the 250 net hp L75 455. 77 of the Supreme hardtops and 66 of the Supreme convertibles with this engine had the M20 4 speed (V Code), so deduct 143. That leaves appx. 2872 cars plus a few built in the final weeks of 1972 production. Some of these were 4 door Supremes too. Maybe a third of these ~3000 cars were convertibles?
The engine option data only exists for the full 4200 Supreme series with no breakdown by hardtop or convertible.
Hope this helps.
Terry
vette442 is offline
Old December 18th, 2017, 03:12 PM
no, that must be someone else, my uncle still has a flip-phone
I found some GM of CANADA decodes for '72 Cutlass Supreme convertibles (34267)
805 total
701 w/L34 350 4bbl (87%)
74 w/L75 455 4bbl (9%)
30 w/L77 W30 455 4bbl (4%)
WARNING BAD MATH! * applying the same 9% to the total 11,571 convertible would give us an approximate ~1,041 L75 convertibles for '72
pretty close to your 1,005 car guess
Old December 18th, 2017, 03:21 PM
vette442's Avatar
Huh, weird to see two very similar requests within a couple days of each other.
Thanks for the Canada numbers - I'll add those to my stats library!
Terry
vette442 is offline
Old August 31st, 2018, 02:50 PM
oldsmobiledave's Avatar
805 total
30 of the 1972 X code L77 W-30 convertibles sold new in Canada. That is interesting as only 113 were made and so 26.5% of 1972 W-30 4 speed rag tops sold new in Canada.
oldsmobiledave is offline
February 1st, 2024 02:55 PM
1972 "U" code
July 21st, 2020 10:02 AM
hotrod1
March 15th, 2017 12:11 PM
mmurphy77
February 5th, 2012 08:16 PM
mdh157
February 8th, 2011 07:08 AM
Quick Reply: 1972 Cutlass Supreme convertible w/455 production numbers
