aluminum radiator
Old Oct 2, 2017 | 05:28 PM
rhaberm's Avatar
aluminum radiator
any suggestions to replace 3 core radiator to aluminum, 69 cutlass 350
Old Oct 2, 2017 | 05:42 PM
76olds's Avatar
Hookers under Hood
I like the Be-cool aluminum rads myself but their are others that will perform well.
Old Oct 2, 2017 | 06:00 PM
zeeke's Avatar
A while back a member posted Pepboys having 4 core copper radiators but by the time I got mine it was aluminum. I kept it and put it in the Cutlass when I dropped the 455 in. I had to change the bottom supports and use the 4 core top plate from the 442. The car now runs, on a hot day at about 180-190 with a 180 stat. Radiator fit near perfect and works great. I think it was around $190 and made in Canada.
Old Oct 2, 2017 | 08:34 PM
Qwik71442's Avatar
Full-time Taxpayer
Have used both of these with good results on 455's says Buick but fit the Cutlass perfectly. You can call them to verify
http://www.speedcooling.com/1968-197...-Radiator.html
http://www.speedcooling.com/1968-197...1-4-TUBES.html
Old Oct 4, 2017 | 10:22 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Those are nice looking rads for the money. Some argue large dual core rads out cool 4 core rads.
Old Oct 5, 2017 | 05:37 AM
jozw30's Avatar
I put a Griffin aluminum radiator in the w30 a few years ago. Has stamped tanks, looks stock when hit with a coat of radiator black. Haven't had any issues.
Helped a lot here in the oven.....
tocicar8825
Sep 21, 2021 07:10 AM
cwracer
Feb 23, 2011 07:54 PM
defiant1
May 19, 2010 04:29 AM
Jhall64
Sep 15, 2009 10:09 AM
cfair
May 31, 2009 09:18 AM
