455 Radiator debate: Aluminum vs Brass
Old May 31, 2009 | 08:37 AM
cfair's Avatar
All,
Just wanted to solicit opinions on the brass vs aluminum debate. I have a couple of 66 big cars, both in good driver shape. Both have the factory shroud and thermally controlled 6 blade fan & recovery tanks (puke tanks) from a mid 70's eldo. My convertible 98 is out getting a new motor and the guys who pulled the motor (a radiator shop) showed me that the old brass rad was blooming at the corners. So I need a new or fixed up radiator.
The refreshed motor will come back running a bit hotter than it went in from the new compression, so to enjoy it for summer when it's hot enough to have the top down, I want to make sure it runs at 180-190 even in traffic.
The choice seems to be 2 row aluminum or 3/4 row brass. My rad. shop guys are suggesting brass. They said there's some new kind of approach with fin counts or tube size that makes things run cooler in traffic. I don't think they do aluminum, so they lean toward brass. That's fine, but I just wanted to confer with you on views about how to keep these big cars cool.
My 66 Starfire is running fine, but I took it on a 250 mile trip Friday and with outside temps in the high 70's in freeway accident-traffic it pushed up to 200 or so within minutes. When I put the A/C it even at 50-60 mph it was pushing 200. So I don't run the A/C much, even though it really works well.
So you can imagine I'm looking for better cooling on both cars. What are your views?
Thanks in advance,
Chris
Old May 31, 2009 | 09:18 AM
AJCDFIN's Avatar
IMO i would think with a/c 2 rows is inadequate,3 or 4 seems best. As far as the 66 todays pump gas causes those early engines to run slightly hotter , but 200 is not overheating with a 195 stat.
jkoester122
Sep 8, 2011 07:48 PM
Joffroi
Nov 6, 2010 02:30 PM
AZ442
Feb 1, 2010 06:38 AM
65 starfire
Feb 2, 2008 07:03 PM
Newkid8
Jan 21, 2008 12:29 PM
