Intake manifold ID
Intake manifold ID
So I saw this on the local Craigslist this morning and wondered if anyone could ID the intake manifold. The ad says they are 1968 parts but the pics shows a set of A heads. I have never seen an intake for a square flange carb with the hot air choke setup - I thought all of the early square flange carbs had a divorced choke?
https://phoenix.craigslist.org/evl/p...214566994.html
1965, the only year the big block used the square bore rather than spread bore pattern. They didn't have the divorced choke in 1965 although on my car there's only one tube coming out of the intake for the carb, the other side is blocked off. A heads, further supports 65 rather than 68. Can you view a photo of the code stamped in the end of one head? If it starts with a V that would be the 442 code, something in demand even if you don't need to use it. John
Just looked at his ad and I think he's pretty high on the value of these parts.
The intake and heads were used on every 1965 BBO.
shamusj
December 18th, 2014 09:28 AM
svnt442
July 17th, 2011 04:43 PM
