Intake manifold ID
Old Jul 15, 2017 | 12:03 PM
Intake manifold ID
So I saw this on the local Craigslist this morning and wondered if anyone could ID the intake manifold. The ad says they are 1968 parts but the pics shows a set of A heads. I have never seen an intake for a square flange carb with the hot air choke setup - I thought all of the early square flange carbs had a divorced choke?
https://phoenix.craigslist.org/evl/p...214566994.html
Old Jul 15, 2017 | 12:16 PM
2blu442's Avatar
1965, the only year the big block used the square bore rather than spread bore pattern. They didn't have the divorced choke in 1965 although on my car there's only one tube coming out of the intake for the carb, the other side is blocked off. A heads, further supports 65 rather than 68. Can you view a photo of the code stamped in the end of one head? If it starts with a V that would be the 442 code, something in demand even if you don't need to use it. John
Just looked at his ad and I think he's pretty high on the value of these parts.
Old Jul 15, 2017 | 01:50 PM
^^^THIS.
The intake and heads were used on every 1965 BBO.
Old Jul 15, 2017 | 03:48 PM
Unfortunately, no.
The guy is asking $800 for two A heads, the intake manifold, unknown cam and lifters, a dampener, and some chrome valve covers.
Old Jul 15, 2017 | 04:07 PM
Yeah, he just isn't an Olds expert. From the ad:
The approximate year is 1968,
Old Jul 16, 2017 | 11:50 AM
I saw that and thought maybe he just mistyped. The 8 is right above the 5 on the key pad, but he has that in two different locations, so maybe he really doesn't know.
shamusj
Dec 18, 2014 09:28 AM
svnt442
Jul 17, 2011 04:43 PM
jjatich
Jul 29, 2007 07:57 PM
SMOKEYMTNKUSTOMS
Oct 12, 2006 12:18 PM
magnusdog
Sep 2, 2006 10:01 PM
