1970 98 true dual exhaust
So my car is in my friends shop today getting duals put on. I didn't realize the manifold configuration as it was a single exhaust and it's all original. Instead of all the hassle of capping the second port and trying to route the new exhaust pipe from the driver side down and behind the steering linkage, could one just add a Y pipe after the passenger side exhaust port to go to two pipes from there? Basically a similar idea to an X Pipe, no? Car is 365 HP 455, 31k original miles.
If you want true duals do it factory style, get the correct manifold for the left side, capping the crossover port on the passenger side is easy. The end result will look so much nicer and perform better as well.
Mendozza, you can weld a Y into the passenger's side exhaust pipe if that's what you want to do. It would probably be cheaper because you wouldn't have to buy a reproduction Thronton's manifold. However, it might no be as good for HP and torque gains. Nothing you will be able to detect with the butt dyno though.
Jun 3, 2019 11:53 AM
2blu442
Mar 7, 2014 06:09 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
