Replacing Clock with 3 Sunpro Mini Instruments- 72 Cutlass
Old Apr 11, 2017 | 08:47 AM
Oldssupreme's Avatar
Chris
Hi! I recently purchased a set of three Sunpro mini 1 1/2" gauges from the 1990's new in the box for oil pressure, volts, and water temp. I wanted to mount these inside the clock housing of my 1972 cutlass and was wondering if anyone had ever done this before? Looking for ideas. Figuring I could do it in a triangle pattern but wondering how I would fill in the empty areas and how I would attach them to the clock housing? Anyone have a photo of how you set up your gauges?
Thanks!
Chris
Old Apr 11, 2017 | 09:06 AM
I don't see the 3 gauges fitting there?
https://classicoldsmobile.com/forums...ock-blank.html
Old Apr 11, 2017 | 10:07 AM
Chris
I believe they are smaller than the ones in that post.
Old Apr 11, 2017 | 01:12 PM
zeeke's Avatar
Just drew it out on paper that's a tight fit anyway you look at it. If you can get all of them in a 3-1/2" hole I'd start by making a template out of light aluminum, cut to 3-1/2", then mark up all three 1-1/2" holes and drill out the center of each to 7/8". Borrow or rent and electricians punch set. Careful, the size you want is 1-1/4" which is a trade size and closer to 1-1/2". Punch each out staying perfectly in the lines. Paint it black, install the gauges. If they fit, take a dummy plate from the A-body dash, cut the back off that, and pop the gauges in there. Problem I see is the dummy gauge is most likely going to be smaller than the space you need. I don't have one handy to measure it so I can't give you that info. If it is in fact to small then trace it around the mounting holes of the dummy gauge and just use the aluminum plate. If it's a 68-69 dash then cut a piece of plexy same size as the hole and push it in the void. If 70 -72 you will need to manufacture something to hold the plexy lense.
Not sure if that's the answer you're looking for but I hope this helps.
Old Apr 11, 2017 | 01:36 PM
Texas69's Avatar
68-69 gauges
FWIW, Here are some pics of Sunpros in a 68-69 clock blank. These look to be 1 3/4" guages and 3 will definitely not fit. The smaller ones may or may not fit.
The clock blank had holes drilled to fit the gauge face and the back of the pod was hacked up and brackets fabricated to work.
I liked the look but replaced the clock pod with a tic-toc-tac.
Old Apr 11, 2017 | 01:44 PM
Chris
Zeeke and Texas 69, thank you for the info. I will try that! Have great day!
Chris
Old Apr 11, 2017 | 08:15 PM
cdrod's Avatar
Rodney
You might be able to use the gauge blank that filled the tach/clock hole. Here's a pic.
Old Apr 12, 2017 | 03:37 AM
Chris
Hi cdrod. Thanks for the suggestion. I had one originally and then I replaced it with a non-working clock and I'm not sure what I did with my blank. Was it metal or plastic?
Old Apr 12, 2017 | 04:23 AM
zeeke's Avatar
Plastic
CROD what are the inside dimensions I couldn't find mine to give him the info.
Chris I just thought of another option. W70442 makes a unit that goes under the dash to mount various accessories, see if he can make something that will work for the gauge insert in your dash. Doesn't hurt to ask.
Old Apr 12, 2017 | 05:15 PM
Chris
Thanks zeeke. I'll look him up.
​​​​​​​Chris
RAMBOW
May 3, 2022 04:25 PM
70Post
Mar 26, 2017 02:30 PM
jtriggy
Jul 20, 2010 04:02 AM
Bryan59EC
Jun 3, 2010 10:36 AM
68Tom
Apr 9, 2009 07:11 AM
