Find anything interesting in your engine?
Old Mar 8, 2017 | 02:38 PM
stephenca118's Avatar
I finally got a chance to take a close look at the engine block after it went through the washing machine at the machine shop.
Pulled these out of the right rear water jacket.
An anode?
Old Mar 8, 2017 | 02:54 PM
tru-blue 442's Avatar
Old School Olds
Wth? Now you're just messing with us...
But seriously, what the heck? I have never heard or seen such a thing, strange.
Old Mar 8, 2017 | 03:32 PM
Nope, true story. I saw these in the back 2 water jacket holes and fished them out with needle nose. Maybe someone thought they are using them as an anode to prevent rust?
I have no idea but they look as if they have been in there for some time.
Old Mar 8, 2017 | 04:21 PM
don71's Avatar
same but different
I don't know what that is. I've seen lots of chunks, usually from the timing chain. Pieces of paper towels, seals from old oil bottles and the usual milkshake grey foamy stuff.
Bits of wire make me think of the original casting process. Which I know nothing about.
Old Mar 8, 2017 | 10:04 PM
Charlie Jones's Avatar
Phantom Phixer
My guess too . Probably extra support for the cores used when casting .
Any foundry workers on here that could confirm this ?
Old Mar 9, 2017 | 03:59 AM
wr1970's Avatar
Core wire for the molds. It didn't come out in the shaker process before block was machined.
Old Mar 9, 2017 | 04:51 AM
gs72's Avatar
72Cutlass S
Yep, I worked at a company that made aluminum engine blocks right out of high school. As an apprentice machinist; one of my jobs was to pull out as much of the casting wire as I could from the raw castings before machining.
Old Mar 9, 2017 | 05:17 AM
Old Mar 9, 2017 | 06:28 AM
wr1970's Avatar
Originally Posted by Olds64
Normal process just got over looked at foundry. Also over looked at the machining shop. Most likely a friday or monday problem or a new hire.
Old Mar 11, 2017 | 10:33 AM
Kennybill's Avatar
My first thought was it was a way of saving a marginal core to get the tolerances +/- in specification. The engine has held up well for 40 + years. I find that the soft plug closest to the oil filter boss has the most "crude" in the water jacket. Jmo.
Old Mar 12, 2017 | 03:31 PM
More stuff?
I have still been cleaning the oil passages of crud in this 371. I had cleaned them out front to back, so to clean them back to front I set the motor on a small table on its nose. While spraying brake clean through the lifter oil holes I looked down and see this laying in one of the cylinders. I have no idea where it came from. I guess it was stuck to the inside of the block with gunk and setting the engine on its nose let it fall out. It is thick plastic with I. C. on it.
I have spent hours cleaning this engine inside and out and suddenly this appears.
Any ideas? Or are the Gremlins messing with me?
Old Mar 12, 2017 | 09:09 PM
gs72's Avatar
72Cutlass S
Kinda looks like a lock tab on an electrical connector.
Old Mar 13, 2017 | 05:24 AM
That small widget looks similar to the tension tabs that hold rear window trim on a car.
Old Mar 13, 2017 | 06:38 PM
bw1339's Avatar
2000A fuse
L77F85
Nov 25, 2018 03:40 AM
L77F85
Jun 26, 2015 09:54 AM
jaunty75
Jul 17, 2013 12:59 PM
Bunser
Mar 27, 2010 10:29 AM
