Trying to stay motivated.
Old May 10th, 2017, 07:00 PM
  #41
Sammy70 455 Supreme
sammy's Avatar
I should research..why did u swap?
sammy is offline
Old May 10th, 2017, 07:17 PM
  #42
Old School Olds
tru-blue 442's Avatar
I like 2 black marks on the pavement when I hit the gas on a 455.
I have the heart ready to go in after the front end gets a rebuild
and the body gets some paint.
The #'s match block is there with the intake and some Ka heads under
the bench for it at a later date.
tru-blue 442 is online now
Old May 11th, 2017, 10:06 AM
  #43
RocketRonnie's Avatar
Hey buddy, seems like I'm confused too. 🤔.
Can you please clear it up for me because I too like to see 2 black lines. Did you switch your gears, the whole differential, or the whole rear end?
Did you swap to the 1970 version becasue it is superior to what was on there originally.
RocketRonnie is offline
Old May 11th, 2017, 04:14 PM
  #44
Old School Olds
Apologies guys. Sometimes my explanations are about as clear
as mud on your windshield after driving through a light rain with bad wipers.
The 70 442 original one wheel peel 3.23 type 0 unit was replaced with one from a 66 442.
It is a 3.23 limited slip (posi) rear. All I did was swap one for the other.
Old May 11th, 2017, 04:20 PM
  #45
Sammy70 455 Supreme
sammy's Avatar
Thumbs up
👍..good idea
sammy is offline
Old May 15th, 2017, 03:07 PM
  #46
Old School Olds
Got the other side today. One thing about primer, it will show you all the dings.
Old May 18th, 2017, 09:54 AM
  #47
Old School Olds
Moving on...
Anyone had to deal with some idiot spraying that expansion
foam into the trunk area? Any removal tips are welcome.
I have an idea I'm going to try. Hot knife through butter as they say.
We'll see how well it will work.
Old May 18th, 2017, 01:09 PM
  #48
Old School Olds
3 hours and 3 & 1/2 beers later, done. Worked pretty well. More work for the body guy though. At least now I can see what's what.
Old May 18th, 2017, 03:22 PM
  #49
Sammy70 455 Supreme
sammy's Avatar
Gotta love that stuff..lol. Good idea with heat. I usually trim it off also to see what's up...
sammy is offline
Old May 18th, 2017, 03:54 PM
  #50
Old School Olds
I was floored someone actually did that to be honest. I have never, ever seen that.
It did cut that crap like butter too. A bit with the dry vac and here's your holes, ha.
Old May 18th, 2017, 04:02 PM
  #51
Sammy70 455 Supreme
sammy's Avatar
Seen it lots of times on the rust belt....any expanding foam will do😜
sammy is offline
Old May 18th, 2017, 04:20 PM
  #52
Old School Olds
Gotcha Ted. Living down South, tin worms are more scarce, thank goodness.
When I lived in the Panhandle of TX, they were even less. Go figure.
Old May 19th, 2017, 04:23 AM
  #53
344879M363895
70-442-W30's Avatar
This is looking good. Great progress. Bet you can't wait to test that posi.
70-442-W30 is offline
Old May 19th, 2017, 05:01 AM
  #54
Old School Olds
Thanks Bill. One day, how soon, I don't know. Trans and front end need to be rebuilt 1st.
I haven't decided yet on weather to go with a rebuild of the 2004R that I have from an 87 GNX or rebuild the turbo 400 OG.
Old June 27th, 2017, 11:57 AM
  #55
Old School Olds
Well fudge...
so I drove over to Seward Junction to get my early 70 trunk lid back from the
soda blaster. What I thought was a good-n-straight and rust free unit...
It had black painted primer on top of yellow paint before it went out, ha.
Like Forest said, "Life is like a box of chocolates, ya never know what your gonna get." Bondo can hide multiple sins, that is for sure. I figure either a 12 gauge slug or a .44. Damn.
Old June 27th, 2017, 02:11 PM
  #56
cjsdad's Avatar
A bullet hole would have torn edges and anything that big would have penetrated the trunk floor as well as the fuel tank. The hole is too irregular for that and the edges are not "punched" through. That looks more like a ground out hole for a CB antenna once upon a time.
cjsdad is offline
Old June 27th, 2017, 02:33 PM
  #57
Old School Olds
10-4 good buddy. I would bet you are right. Back in the 70's everybody had CB radios.
It can be fixed with metal pretty easily I hope.
Old June 27th, 2017, 03:21 PM
  #58
Sammy70 455 Supreme
sammy's Avatar
Awe the 70's....had to put one in my Cutlass👍😜...keep the hole...lol
sammy is offline
Old June 27th, 2017, 03:22 PM
  #59
Sammy70 455 Supreme
sammy's Avatar
Upside down...again!
sammy is offline
75cutlass442
October 26th, 2012 09:35 AM
blkmonday
August 28th, 2008 01:04 PM
projectheaven
Brakes/Hydraulic Systems
July 20th, 2008 07:03 AM
allthumbs
July 26th, 2007 08:31 PM
2 door cut
November 9th, 2006 08:28 PM
Quick Reply: Trying to stay motivated.
