1970 442 W30 Fuel Pump
Old Jul 23, 2016 | 10:21 AM
TicTocTach's Avatar
Hey guys, does anyone know what the correct part number would be for a 2 line pump in a 70 W30? One line in, 1 return. It is one of the last pieces i need for my correct build. I cant seem to find anything online with the correct part number so hopefully someone can help me out. I am looking to purchase a NOS pump with the correct number on it so if anyone has one, please message me. Thanks!
Old Jul 23, 2016 | 11:36 AM
My442's Avatar
40736
Old Jul 25, 2016 | 04:47 PM
BlackGold's Avatar
I believe that 40736 is an aftermarket part number.
The original factory-installed AC Delco pump for 1970 W-30s was 6440712. But good luck finding one.
Old Jul 25, 2016 | 08:55 PM
66-3X2 442's Avatar
The OEM pumps are not ethanol compatible. Carter makes an Olds pump that is compatible It has the return line and I have it on my 66 442 and it works great.
https://www.summitracing.com/parts/c...ake/oldsmobile
Old Jul 26, 2016 | 03:53 PM
BlackGold's Avatar
For what it's worth, the pump pictured in your link does not have the same inlet and outlet configuration as the original for a 1970 W-30. Maybe it's correct for '66, and maybe it can be made to work for a '70, but the connections will need modification.
Old Nov 16, 2016 | 11:21 AM
TicTocTach's Avatar
Yes, the correct part number that i need is 40712. If anyone has one, please let me know. Thanks so much!
70-442-W30
Sep 2, 2024 11:47 PM
joesw31
Jun 8, 2016 07:11 PM
Daverd
May 28, 2014 09:26 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
sshriber
Mar 22, 2010 06:16 PM
