Please help! Vin location 56 98
Old Jun 28, 2016 | 01:01 PM
cmpcpro's Avatar
Hey guys I'm stuck here trying to register my car and they need a second vin can anyone locate one? Thanks!
Old Jun 28, 2016 | 01:21 PM
Should be on the driver's side forward door jamb, just under the top hinge:
Old Jun 28, 2016 | 02:00 PM
cmpcpro's Avatar
Thanks but they need two and that is the only one we have found so far.
Old Jun 28, 2016 | 02:09 PM
Why do they need two? The car only has one.
That's the whole point of a VIN - there is a single unique number that identifies a particular car.
Old Jun 28, 2016 | 02:10 PM
cmpcpro's Avatar
CA requires two vin numbers and evidently there are numbers stamped all over the frame and other spots.
Old Jun 28, 2016 | 02:25 PM
jaunty75's Avatar
You need to inform California that this might be true today, but it certainly was not back in the 1950s.
Old Jun 28, 2016 | 02:27 PM
jaunty75's Avatar
He means the same VIN, but appearing in more than one place on the car. I don't think he's going to find that on a '50s car. At least, if there is a second location for a VIN, the body might have to be lifted off the frame to find it.
Old Jun 28, 2016 | 02:28 PM
F-rd used to stamp a VIN on the frame on the driver's side, forward of the firewall, going back to the '30s, as far as I know, but I'm not sure whether GM did that.
Old Jun 28, 2016 | 03:18 PM
cmpcpro's Avatar
I had to go to CHP and they put it on a lift and had these old books from the 50's on where to look and they found the vin stamped on the frame so evidently they did do that back then! Good thing it was the original frame!
Old Jun 28, 2016 | 03:59 PM
cmpcpro's Avatar
Thanks but it's all done and registered! Finally!!
Old Jun 28, 2016 | 04:10 PM
jaunty75's Avatar
Cool. Shows what I know.
Old Jun 28, 2016 | 04:38 PM
I don't know when they started the frame stamp, but it goes back to at least the 30's.
Old Jun 28, 2016 | 05:19 PM
cmpcpro's Avatar
I know it's off topic but I am trying to buy stock steel wheels for my car do you know what type I need? Coker tires has some for $86 ea brand new but I don't know the size. Thanks!
Old Jun 28, 2016 | 08:05 PM
Tedd Thompson's Avatar
Generally the frame vin can be found on the passenger side inside rear frame wheel arch at the top. Most I have seen if you can find it are stamped very lightly and heavy rust will take it away. I've never had to show a second vin number and I live in CA. also. Is this something new?.... Tedd
Old Jun 28, 2016 | 08:22 PM
cmpcpro's Avatar
It's because the car left the state for a few years so it had an out of state title when it came back
Don Bunnell
May 8, 2020 02:15 PM
jordan479
Jul 26, 2016 06:34 AM
justinj
May 7, 2012 10:55 AM
NastyNate6695
Jan 1, 2012 11:49 AM
Chumley
Mar 9, 2011 03:22 PM
