Please help! Vin location 56 98
He means the same VIN, but appearing in more than one place on the car. I don't think he's going to find that on a '50s car. At least, if there is a second location for a VIN, the body might have to be lifted off the frame to find it.
I had to go to CHP and they put it on a lift and had these old books from the 50's on where to look and they found the vin stamped on the frame so evidently they did do that back then! Good thing it was the original frame!
Generally the frame vin can be found on the passenger side inside rear frame wheel arch at the top. Most I have seen if you can find it are stamped very lightly and heavy rust will take it away. I've never had to show a second vin number and I live in CA. also. Is this something new?.... Tedd
