Edelbrock carb to an Olds throttle
Old June 27th, 2016, 12:42 PM
Cpriester123's Avatar
Hey everyone, so after looking at my Edelbrock 1406 I've noticed ALOT of play in the throttle. Come to find out, the throttle cable setup must be incorrect because I looked at the linkage on the original and where the throttle connects is different. The original is ribbed as pointed out. But I also saw where the throttle return spring was hooked here instead, in other pics. If some of you have pics of the correct or similar set up PLEASE HELP. Thanks!
Cpriester123 is offline
Old June 27th, 2016, 12:47 PM
Versus my incomplete set up
Old June 27th, 2016, 03:14 PM
svnt442's Avatar
First use this in the hole that you have your spring attached to and attach the spring in the small hole below it.
https://www.holley.com/products/fuel...age/parts/6026
Then try this in the end of your cable so it will fit on the stud.
https://www.holley.com/products/fuel...s/parts/26-103
svnt442 is offline
Old June 27th, 2016, 03:20 PM
72 Olds CS
RetroRanger's Avatar
I just used a bolt and nut w a plastic spacer in the hole where your return spring is. The olds cable rode on the plastic spacer so it would move smoothly. The return spring on mine was on the bottom thrttle arm and attached to the lower part of the throttle cable Brkt. The set up worked fine but I have a qjet on it now.
RetroRanger is offline
Randy your links are for the 2 alternative bushings for the carb. His spring should attach in the small hole under the hole its attached to now.
oldcutlass is online now
Old June 27th, 2016, 03:45 PM
svnt442's Avatar
I changed that immediately after I posted it.
svnt442 is offline
svnt442's Avatar
And I figured he could use the bushing in the cable end and the aluminum one for the carb.
svnt442 is offline
Old June 27th, 2016, 04:11 PM
A picture of his cable end would help me determine which part to recommend.
Old June 27th, 2016, 06:57 PM
svnt442's Avatar
There it is.
svnt442 is offline
Old June 27th, 2016, 07:25 PM
Full-time Taxpayer
Qwik71442's Avatar
http://www.ebay.com/itm/1970-1971-19...item5b1f07ce7a
And this
http://www.jegs.com/i/JEGS-Performan...57201/10002/-1
You can also screw the stud above into this if you want to use the large carb hole.
http://www.jegs.com/i/JEGS-Performan...15219/10002/-1
Qwik71442 is offline
Old June 27th, 2016, 07:56 PM
Quick posted the bushing that should work,
And Randy posted this one earlier that will work in conjunction with your current stud.
Old June 28th, 2016, 07:20 AM
The stock throttle cable is supposed to have a rubber bushing with a plastic sleeve in that hole. They are available from the usual repro parts sources.
joe_padavano is offline
defiant1
February 4th, 2020 08:53 PM
1965cutlassragtop
March 18th, 2017 06:59 AM
defiant1
February 16th, 2014 06:00 PM
MJAKS462
April 7th, 2010 03:14 PM
viper771
March 2nd, 2010 05:20 PM
Quick Reply: Edelbrock carb to an Olds throttle
