Engine Paint
Old May 3, 2016 | 08:41 PM
Romeo442's Avatar
Unhappy Engine Paint
I have a 1972 cutlass 442 with a 455! I just painted my engine with POR15 and already I'm getting change of color by my intake and by my exhaust manifolds. What paint brand do you all recommend. I contacted POR15 and they told me this is common for Oldsmobiles and Pontiac engines.
Check out the pictures.
Old May 3, 2016 | 09:03 PM
Gary's 2 442-S's Avatar
Gary
Please try this company.
http://www.hirschauto.com/ENGINE-ENA...T/OLDZ%20BRZN/
That always happens. It happened when they were new.
It even happens no matter how many identical threads you start about it.
https://classicoldsmobile.com/forums...ine-paint.html
Welcome to ClassicOlds.
Old May 3, 2016 | 09:04 PM
Old May 3, 2016 | 09:05 PM
Old May 4, 2016 | 06:22 AM
As Eric points out, no paint will survive the heat from the crossover. Also, you need to lose the incorrect Pontiac blue paint anyway.
Old May 4, 2016 | 06:30 AM
88 Cutty Classic's Avatar
X 2 on Bill Hirsch paint
Old May 4, 2016 | 06:33 AM
ANY paint will burn over the crossover.
Old May 4, 2016 | 07:06 AM
I like Bill Hirsch paint. I use Bill Hirsch paint.
I've driven by the warehouse and bought Bill Hirsch paint from Bill Hirsch himself.
If you really want, I'll post photos of the same spots painted with Bill Hirsch paint, burned the same way.
Old May 4, 2016 | 07:08 AM
You'll have to post those photos three or four times...
Old May 4, 2016 | 09:37 AM
4speed455's Avatar
I painted my manifold with por20 aluminum coating. Mine did not discolor at all. I also painted my headers. The headers did blister in a few places, I believe because there was oil on the tubes. It did not discolor on the headers either.
Old May 4, 2016 | 09:49 AM
Octania's Avatar
Me, I think it's ok if a used engine shows signs of.... use.
Old May 4, 2016 | 09:54 AM
Is your crossover blocked?
That was special header / exhaust manifold paint.
Old May 4, 2016 | 10:06 AM
4speed455's Avatar
Crossover is not blocked. I was going to block them but heard a lot of stories of the plugs getting loose and rattling around. The por20 is a special header and manifold coating that has aluminum in the paint and only available in aluminum color. I just looked on their website and it says por20 has been replaced with their high temp paint. Apparently it does like the heat as much as the por20.
Old May 4, 2016 | 10:18 AM
If the crossover is not blocked, and the clearcoat has not discolored, then that's a very impressive clearcoat.
You'd be hard pressed to find a colored engine paint that will do that, though.
Old May 4, 2016 | 10:22 AM
4speed455's Avatar
It's not a clear coat it is aluminum color, which made the old stained manifold like new again. I agree though no regular colored paint would last. On my small block I painted the manifold gold. After a few short drives it burned near the crossover.
Old May 4, 2016 | 10:24 AM
My442's Avatar
Block crossover;
Have intake and exhaust manifolds ceramic coated;
That will allow everything to look new for years.
Old May 4, 2016 | 09:50 PM
Romeo442's Avatar
Sorry I'm new to this forum.
Old May 4, 2016 | 09:53 PM
Romeo442's Avatar
Thank you
I appreciate everyone's feed back!!
Old May 5, 2016 | 07:19 AM
I see people do this is all forums. I just don't understand why folks think they'll get an answer faster or better by carpet-bombing the site with the same question. It's actually in your best interest to keep all responses in a single thread, since that allows folks to spot and correct bad information that may have been posted. Good luck.
Old May 6, 2016 | 09:37 AM
I had a shop powder coat a set of valve covers for my 64 98. They turned out great. Of course, valve covers don't run hot like exhaust manifolds, but you can get different kinds of coating.
My headers are the coated ones and they aren't discolored at all.
Old Aug 17, 2016 | 06:25 PM
Mike Sundy's Avatar
I've been told to use wood stove paint on headers, has anyone tried that?
Old Aug 18, 2016 | 05:49 AM
I used BBQ grill paint on exhaust manifolds before. It worked ok. The paint did eventually burn off, just like the VHT Superhot I tried. I think the only way to get a good coating on manifolds or headers is powder / ceramic coating or chrome.
Old Aug 18, 2016 | 09:09 AM
TripDeuces's Avatar
I'll just add to all this that if you start off with a shiny or glossy coating on anything that gets hot it will eventually turn dull or satin like. It may not burn or discolor and get brown but they dull every time. It's the nature of the beast.
Old Aug 18, 2016 | 02:15 PM
Cincinnati Rick's Avatar
I put out good money for stainless headers and they discolored almost immediately. The motor has about an hour of run time on it. I'll live with it but I wish I would have bought ceramic coated headers.
Old Sep 8, 2016 | 07:31 PM
Shradezz70S's Avatar
Powder coating holds up well but colors are limited.
Jamesbo
Paint
Jun 13, 2020 09:02 PM
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
dlmsavings1
Sep 3, 2013 09:01 AM
805cut
May 3, 2012 08:11 PM
