Where to mount engine hoist
Old Jan 4, 2016 | 05:12 PM
1983oldsmobiledelta's Avatar
Where do I mount engine hoist chain on 307 thanks
Old Jan 4, 2016 | 05:24 PM
lemoldsnut's Avatar
On the passenger side back of the block there is a hole in the block. It is sideways. Then you have a loop hook on the intake on the front of the engine on the drivers side. I made a pull chain with a hook from an old tie down strap on each end. It is a quick hook up works great.
Old Jan 4, 2016 | 06:43 PM
I've been using a carb plate for the last 30+ years.
Old Jan 5, 2016 | 07:19 AM
The safest thing to do is to run a chain from the accessory bolt holes on the front of one head to the back of another. Use grade 8 bolts. Be sure the chain link is right up against the head so the bolt isn't put in bending.
oldspackrat
Apr 17, 2013 07:59 PM
Al2011
Jul 22, 2011 03:18 PM
1973olds98
Oct 15, 2009 04:03 PM
rockethound
Jul 23, 2009 05:29 PM
Jolly Green
Apr 2, 2008 01:04 PM
