will quarter panels cut off 4 door work for 2 door ( 69 ) cutlass
Old Feb 17, 2009 | 01:18 PM
jmac69cutty's's Avatar
Question will quarter panels cut off 4 door work for 2 door ( 69 ) cutlass
will rear quarter panels off a 69 olds cutlass 4 door ( off a front end wrecked 4 door ) also has nicce dash and tons off extra parts, and i have 2 69 2 dr HT's right now ) w
will these fit on my one needs rear 1/4 's
is this posible just a little more work or...
will this not even be close ?
thanks ,
oh yah and how much do you think its worth it dosent look to have any rust but has probly got a little bit off frame damage thanks
Old Feb 17, 2009 | 01:53 PM
seing if this works
Old Feb 17, 2009 | 03:06 PM
69Rman's Avatar
That all depends on how much of the quarter panel you will need.
The 4 door cars have virtually no "forward" section of the quarter panel.
See this car below...
Right behind the door there is nothing there if you need any of this area.
If all you need is the rear most area then you would probably be ok.
I do believe that the top edge of the quarter panel on the four doors is a different angle then on the 2 doors, but you probably only need the lower area.
Duane
Old Feb 17, 2009 | 04:07 PM
If your plan is to use a 4dr quarter to replace the crumpled quarter in the picture, sorry, not even close. Patching in a 4dr quarter will likely be even more work than using the Chinesium repro quarters. Best bet is pay the money for a good original quarter from the southwest. Be sure the seller cuts it above the factory seam at the roof. The extra cost will be more than offset by the labor savings, not to mention the better quality of repair.
Old Apr 12, 2009 | 11:50 PM
Yellowstatue's Avatar
Smile Bustle
The back end of a four door is the same stuff as a convert...trunk lid and quarters...except the quarters are not as long of course...keep it for a convert repair...
Old Apr 13, 2009 | 07:42 AM
The trunk lid is the same on a convertible. The quarters are not.
yamahondarider
23
Apr 20, 2018 06:31 AM
Octania
Oct 8, 2013 07:56 PM
62radarlove
May 16, 2012 10:15 PM
cutlass47
Nov 6, 2010 07:39 PM
jtriggy
Jul 13, 2010 11:58 AM
