Best place for cut-off switch? (1970 Cutlass)
Old Jul 13, 2010 | 07:30 AM
jtriggy's Avatar
Hi Folks,
What wire would be the best to splice for a push button cut-off I want to install under my dash. I understand this wouldn't prevent someone knowledgeable from starting the car but I simply want to make it a little more difficult for them.
I assumed the purple wire going to the starter but you may have a better idea?
I'm also going to do a hood lock.
Thanks,
James
Old Jul 13, 2010 | 08:24 AM
Run to Rund's Avatar
The wire for the neutral start switch (purple).
Old Jul 13, 2010 | 10:24 AM
jtriggy's Avatar
Sorry, I am not asking where to put the button, I'm asking what wire is best for a cut-off.
Thanks,
James
Old Jul 13, 2010 | 11:05 AM
mlouderback's Avatar
I have my kill switch between the hot wire running from the fuse block and the HEI ignition.
Old Jul 13, 2010 | 11:53 AM
jaymann's Avatar
Thanks,
James
I was jokingly referring to Jefrey's post... it looks like he deleted it, so I'll delete mine too.
I usually use a battery kill switch under the hood, they work great when your car is being parked for long periods.
For cars that get driven more then once a weekend it's a pain in the butt popping the hood everytime you wanna go somewhere.
I like tapping into the power to the coil or HEI. That way the car still cranks but won't fire. If someone's messing with your car and tries to fire it up you'll hear it!
It's also great for when you're working under the hood and need to bump the engine over without it firing.
Old Jul 13, 2010 | 11:58 AM
jeffreyalman's Avatar
sorry the title of the post threw me off
yamahondarider
23
Apr 20, 2018 06:31 AM
QS442
Jul 31, 2015 06:04 AM
projectheaven
Sep 14, 2011 08:10 AM
cutlass47
Nov 6, 2010 07:39 PM
jmac69cutty's
Apr 13, 2009 07:42 AM
