who carries a replacement shifter cable?
Hi all! been a while since I've had a chance to play on computer.
Been building a new garage to keep the 70 in
am converting from column shift to floor shift.who sells the floor shift cable?this is a 70 A body cutlass supreme.The buckets and console are 70 A body also.I looked at OPG and Classic Industries and didn't see anything for cutlass.Who carries one and which is best?Many thanks for any replies
I can't see why you'd need a special one.
Just measure what you need and order one from Summit.
http://www.summitracing.com/search/?...%20cable&dds=1
console came with brackets but have not mounted or welded any into place as of yet.I laid them out according to the dimples in the floor pan and everything seemed to line up but that was last year and didn't snap any pics.Are there different points that line up also?thanks for any extra info
