who carries a replacement shifter cable?
Old May 16, 2011 | 07:08 PM
meoff's Avatar
Hi all! been a while since I've had a chance to play on computer.
Been building a new garage to keep the 70 in
am converting from column shift to floor shift.who sells the floor shift cable?this is a 70 A body cutlass supreme.The buckets and console are 70 A body also.I looked at OPG and Classic Industries and didn't see anything for cutlass.Who carries one and which is best?Many thanks for any replies
Old May 16, 2011 | 07:23 PM
oldspackrat's Avatar
you have a pm.
Old May 16, 2011 | 07:51 PM
Aceshigh's Avatar
I can't see why you'd need a special one.
Just measure what you need and order one from Summit.
http://www.summitracing.com/search/?...%20cable&dds=1
Old May 16, 2011 | 09:27 PM
lrbeavers's Avatar
I got one from eBay, did you get the mounting brackets, if so send pictures where you mounted them
Old May 17, 2011 | 05:58 PM
meoff's Avatar
console came with brackets but have not mounted or welded any into place as of yet.I laid them out according to the dimples in the floor pan and everything seemed to line up but that was last year and didn't snap any pics.Are there different points that line up also?thanks for any extra info
Old May 17, 2011 | 06:00 PM
meoff's Avatar
Originally Posted by oldspackrat
you have a pm.
thanks Scot and sent a return pm
Old May 17, 2011 | 06:12 PM
meoff's Avatar
since it never had a cable thru the floor I figured if I got the right one the first time then there would be no guessing as to where it should penetrate the floor pan and how it should route.
defiant1
Feb 4, 2020 08:53 PM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
weasel
Feb 8, 2011 07:36 PM
ct1979
Dec 21, 2006 03:08 PM
