What shop light do you use?
Old Jan 19, 2022 | 08:59 AM
What light do you use when working on your Olds? I had a HF shop light that broke pretty quickly and the Husky one I have is a POS. The hook broke the first time I used it and the magnets are only strong enough that it falls off the underside of the hood every 10 minutes.
https://www.homedepot.com/p/Husky-80...0228/305124388
Old Jan 19, 2022 | 09:03 AM
I use something similar to this with an LED bulb. Not overly complicated and works well.
HDX 75-Watt Metal Shield Incandescent Trouble Work Light with 6 ft. Cord-HD-408PDQ - The Home Depot
Old Jan 19, 2022 | 09:24 AM
fleming442's Avatar
NEIKO 40447A Rechargeable...
Amazon Amazon
Old Jan 19, 2022 | 09:29 AM
OLDSter Ralph's Avatar
I think the type you use with LED bulbs, flood the work area well.
Old Jan 19, 2022 | 09:49 AM
442Dude's Avatar
I have several of these and love them......they charge quickly with a rapid charger and last awhile. Light is super bright.
390 Lumen USB Rechargeable Work Light, COB Work Lights with Magnetic Base Ultra Bright LED Flashlight - - Amazon.com 390 Lumen USB Rechargeable Work Light, COB Work Lights with Magnetic Base Ultra Bright LED Flashlight - - Amazon.com
Old Jan 19, 2022 | 10:19 AM
RetroRanger's Avatar
72 Olds CS
Ive got a couple different lights, corded, rechargable theyre all ok.
my goto is two rechargable headlamps, i used to have the aa battery style hedlamp, but batts last 15 hours and battery leaking were issues.
i picked up some rechargable ones and theyre lighter, and have a good run time 15-20hrs before recharge, with two of them ones always GTG.
the best part hands free no futzing w the light once its adjusted …where your looking is where the light is shining, these work great and are really bright…..ill post a link later
link
Amazon Amazon
Old Jan 19, 2022 | 10:37 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have the Ryobi One 18 volt LED, just picked it up, very bright and multi directional. I also just bought the 650 ft/lbs 18 volt impact.
https://www.homedepot.com/p/RYOBI-ON...P727/207017500
Old Jan 19, 2022 | 12:12 PM
VC455's Avatar
Barely Registered
Engr
Same here. I bought an an all-plastic version of that 20 years ago. It has a 20 ft cord and I use it with a 100 W LED lamp. It lights an entire area, no need to aim it.
It still works well, and it has a 120 V outlet in the handle for a soldering iron or whatever.
Old Jan 19, 2022 | 01:48 PM
Sugar Bear's Avatar
Bayco brand works. Look for cordless rechargeable to keep the floors clear of trip hazards.
Old Jan 22, 2022 | 12:35 AM
Ozzie's Avatar
Amazon Amazon
Old Jan 22, 2022 | 01:05 AM
VI Cutty's Avatar
I've gone the Milwaukee route with a lot of my tools, M18 and M12. My daughters got me this M18 worklight for Christmas and I've been putting it to a lot of use and really like it. It has 3 brightness settings (and bright is BRIGHT). The light can be adjusted from 360 degree flood down to 180 degree which is where I usually have it.
https://www.milwaukeetool.com/Produc...Lights/2363-20
Old Jan 22, 2022 | 02:19 AM
oldsrock's Avatar
I’m using this ATD 80357 Saber under hood light. It’s big, bright and well built. Cordless works for quite a long time. The cord is really long too so easy enough to just keep it plugged in. Wide enough to hang on hood or even the roof if your working on the interior.
https://atdtools.com/80357
Old Jan 22, 2022 | 05:09 AM
ignachuck's Avatar
Frank Ignachuck
I have this one ^^^^^
BSiegPaint
Aug 30, 2021 01:46 PM
brucegroesbeck
Jul 19, 2019 10:36 PM
pogo69
Jun 24, 2013 06:26 AM
68442Convertible
Jul 5, 2012 10:25 AM
70CCV
Jun 17, 2011 05:24 AM
