What goes here??
Old September 22nd, 2016, 01:55 PM
Cpriester123's Avatar
What goes here??
I've looked all through the 1969 Fisher Body Manual and could not find what actually goes here. Trying to find the correct name so I can order them and install them if I know where to get them from. If anyone can help I would greatly appreciate it. Thanks in advance.
Cpriester123 is offline
Old September 22nd, 2016, 02:51 PM
oldspackrat's Avatar
Door jamb bumpers & I call the other piece a door jamb U shaped seal.
oldspackrat is offline
Old September 22nd, 2016, 02:58 PM
Randy C.
rcorrigan5's Avatar
The pieces on the doors are called "door lock pillar bumpers". You should have 4 of them - two for each door. They are rubber. If you look at www.Fusick.com and their on-line catalog, you should find them under part number DB90 at about $3.50/each.
The other piece is called the "body pillar sealing strip". It can also be found at the Fusick site with part number BP5455 at around $24/pair.
The last time I used Fusick I noticed some of the part numbers have changed. If you don't find these parts by the part number I gave, try using the name of the part for searching.
Randy C.
rcorrigan5 is offline
Old September 22nd, 2016, 02:59 PM
The rubber bumper kits are available at most resto suppliers.
Ushaped door jamb seal can be had at reto suppliers
oldcutlass is online now
Old September 23rd, 2016, 12:32 PM
Note that there are two heights of these bumpers.
I don't recall which is correct for A-bodies, but if you get a set and it seems like they don't even touch, or the door won't close, you've got the wrong height.
MDchanic is offline
Dead Reckon
July 12th, 2015 10:03 AM
MBrown
December 16th, 2012 05:39 PM
1970 Post
July 27th, 2012 06:01 PM
1972_442
Brakes/Hydraulic Systems
July 4th, 2008 05:22 PM
denis
December 22nd, 2006 05:03 AM
Quick Reply: What goes here??
