Brake goes straight to the floor
Old Nov 18, 2007 | 03:11 PM
1972_442's Avatar
Ive bleed these brakes for over 4 hours and every time the brake pedal still goes straight to the floor when the engine is running, the wheel cylinders, rubber brake lines, and master cylinder were all replaced and i bench bled the master cylinder but still have no breaks. could it be the booster? is it common to need to replace the metal lines? this is a very aggravating problem. i was going to do a disc brake conversion should i just go ahead and do that?
Old Nov 18, 2007 | 04:27 PM
kevinkpk's Avatar
If you have no external leaks, then you have an internal leak, check the vacuum booster.
Old Nov 18, 2007 | 04:36 PM
Dapapadon's Avatar
Or a bad master cyclinder.
Old Nov 18, 2007 | 04:45 PM
kevinkpk's Avatar
yep, an internal leak, master cyl. could be bleeding through the front and rear.
Old Nov 21, 2007 | 01:33 PM
Modern Motoring's Avatar
if it's taking you 4 hrs to bleed brakes, I would recommend that you NOT go ahead and do a disc brake conversion. You think you're aggravated now? Holy Crikey! Call Booster Dewey in Portland Or. Tell him what is happening, dime to a donut it's the booster.
Old Nov 21, 2007 | 03:54 PM
1972_442's Avatar
yea i went ahead and got a new booster, i know i dont think its the master cylinder because its the second one ive put on the car. the white plastic sleeve on the back of the booster was cracked in some places would that affect the brakes. id have to order it from year one but i really dont want to wait a week just to put the new booster back on.
Old Nov 21, 2007 | 05:15 PM
ozoneblue's Avatar
When you bench bleed the master CYL. Do not push in over 1" that will cut the new seals to bleed system start with RR & let it gravity bleed -Drip for a while then LR RF &LF Keep a eye on your fluid level.
Old Jan 4, 2008 | 06:42 PM
crackie's Avatar
Bleeding 57 Oldsmobile brakes
I had the mastercylinder and booster rebuilt and I bench bled it and put on car but couldn't get it to bled , I was told that when I pushed the plunger all the way down when I bench bled that it cut the seals is this true. Crackie
Old Jan 5, 2008 | 09:16 AM
Oldsguy's Avatar
Past Administrator
yes, as ozoneblue posted just above....it is true.
Old Jul 3, 2008 | 10:44 AM
Kaline's Avatar
Booster Issue?
1972 442:
Did your new booster take care of the issue? I'm having a strange issue on my '64 Dynamic 88. The brake pedal was not returning and the fluid in my master cylinder was rusty, so I went ahead and installed a new master. However, when the engine is running the brake pedal drops to 1/2 its normal height and the engine nearly stalls when I hit the brakes (I have the car on jackstands). When I shut the car off, the brake pedal returns to its normal height after 10 seconds or so. I figure it is probably the booster. Any ideas?
Old Jul 4, 2008 | 05:22 PM
Kaline's Avatar
Update to my question (above): I installed the wrong master cylinder on my car. I have a Bendix brake booster and I installed a rebuilt Moraine master cylinder (which is what was on the car). That is why I was having issues, and why the previous owner had brake problems! Off the auto parts store I go, to order the proper master cylinder!
UPDATE 7/12/08: I installed the Bendix master cylinder, but I still have the same issue. Actually, the booster pulls the brake pedal down when the engine is running whether there is a master cylinder attached to the booster or not. Also, the brake pedal has a "catch" at about 1/2 travel, which does not feel super-safe. Is it safe to assume my brake booster needs rebuilt? Who do forum members recommend tp rebuild the booster?
805cut
Jun 8, 2012 03:15 PM
gearheads78
Dec 14, 2011 06:08 PM
defiant1
Sep 10, 2011 01:26 PM
Yellowstatue
Aurora
Jun 17, 2010 03:20 PM
OLD SKL 69
Jan 2, 2009 06:57 AM
