Washing engine questions
Old July 17th, 2017, 11:51 PM
Tymiles24's Avatar
I need to wash my engine and since this is the first 330 rocket I've ever owned, iam curious what should I avoid and what should I wrap in plastic for protection. Here is some pictures of my engine and engine bay.
Tymiles24 is offline
Old July 18th, 2017, 12:06 AM
'87 Delta 88 Royale
rustyroger's Avatar
Obviously the important thing is making sure water doesn't get into the carb and inlet manifold, or the crankcase, and the distributor.
So wrap the carb in a plastic bag and secure it with a ziptie, if it has an open breather plug that, and wrap the distributor as well.
Avoid sending water into the generator if you are using a power washer, and blasting directly onto the radiator core.
Don't forget to pay particular attention to the bottom of the engine, crud not only makes changing the oil a messy chore, but it also inhibits the ability of the oil pan to dissipate heat. And of course it doesn't look good when someone wants to admire your pride and joy in detail!.
Roger.
rustyroger is offline
Old July 18th, 2017, 12:19 AM
Tymiles24's Avatar
Cool...thanks for the advice....is there a preferred degreaser to use or will simple green do the trick?
Old July 18th, 2017, 12:33 AM
'87 Delta 88 Royale
rustyroger's Avatar
Well I use a product called Jizer. Good like finding it over there.
Ask at your auto parts store, or better still call at a truck shop and ask what they use.
Roger.
Old July 18th, 2017, 12:38 AM
Tymiles24's Avatar
Ok cool ....thank u
Old July 18th, 2017, 04:09 AM
I do it with the engine running. Do not spray directly on the air cleaner, distributor, alternator, voltage regulator, or connectors under the master cylinder. First spray the engine down with degreaser of choice and then use the water to rinse it off.
oldcutlass is online now
Old July 18th, 2017, 05:56 AM
Tymiles24's Avatar
That's how I use to do it in my other cars.
Old July 18th, 2017, 12:17 PM
D. Yaros's Avatar
Would it not be as acceptable to do it with the engine off/cold and then use a leaf blower to clear away the remaining water?
D. Yaros is offline
Old July 18th, 2017, 12:23 PM
Tymiles24's Avatar
That's a great idea...I am going to take a stab at it after work today...I'll let u guys know how it turns out. I'll either have a clean engine or be dead at the car wash..lol
Old July 18th, 2017, 01:30 PM
jaunty75's Avatar
Here's a video on cleaning an engine bay. I haven't done it myself, yet, but I thought this was pretty good.
jaunty75 is offline
Old July 18th, 2017, 04:17 PM
Frank Ignachuck
ignachuck's Avatar
Back in the day (the mid 60's) I used to hang around the local Dodge dealer in town and they would get the car up to running temp, shut it off, sprinkle Tide on the engine, spray it off, and start the car right up quickly.
ignachuck is offline
Old July 18th, 2017, 05:03 PM
Tymiles24's Avatar
Lol...I like that idea.
Old July 18th, 2017, 08:45 PM
Tymiles24's Avatar
Just masked off and sprayed degreaser
Old July 18th, 2017, 08:48 PM
m371961's Avatar
Do not put it in the dishwasher.
m371961 is offline
Old July 18th, 2017, 08:52 PM
Tymiles24's Avatar
Dishwasher?
Old July 18th, 2017, 09:24 PM
Tymiles24's Avatar
Looks a little better
Napoleon Solo
March 27th, 2015 09:35 PM
oldspackrat
August 29th, 2011 05:06 AM
Gunfreak25
February 14th, 2011 08:58 AM
Destructor
July 13th, 2010 05:43 AM
85LS
March 2nd, 2009 12:38 PM
Quick Reply: Washing engine questions
