Want to install my electric choke
What step do i do to remove existing pipes what needs to be caped off and do they sell a block plate for the intake.if anybody have pics that would be a plus thanks.
Remove the two tubes that go to the manifold heat stove. They should pull out of the manifold plate. You don't need to do anything to the plate. It will not leak exhaust unless it is rusted out inside. Cap the port at the top rear of the carb and the port at the choke housing.
Rob, here is an electric choke kit:
http://www.summitracing.com/parts/EDL-1932/
I installed one of these on my Q-jet and it works great!
debfahey
October 4th, 2014 09:10 AM
easytobedead
February 13th, 2009 10:02 AM
