w31 options and Vin derivitive/serial number discussion
Old Dec 15, 2024 | 04:35 AM
  #41
TK-65's Avatar
You lose. Good day sir.
Old Dec 15, 2024 | 07:59 AM
  #42
Seek help.
Old Dec 15, 2024 | 10:49 AM
  #43
CANADIANOLDS's Avatar
Nope..the GM docs I posted on how to locate and decipher the “serial number” put out by GM is the winner. you wouldn’t have a case at all if you went to court with what you have😂😂😂
don’t be so foolish.
Old Dec 15, 2024 | 10:51 AM
  #44
Seek help.
😂😂😂😂 you’re not the brightest bulb on any tee, anywhere.
you prove it whenever you post
Old Dec 15, 2024 | 11:30 AM
  #45
2023 HR article sponsored by Mecum.. not once is “derivative” “VIN derivative” or “derivative of the VIN” mentioned. It’s referred to as “Serial Number” or “serial sequence number” or “Sequence number” or “sequential number”. The dictionary meaning of sequential is a SERIES of numbers in ascending or descending order to provide a unique number system to identify an item in the SERIES or SEQUENCE
GM starting using the term sequential number in place of serial number in the later part of the 1980’s. although it’s meaning is the same.
pic from Mecum article and link to full article below
https://www.hotrod.com/how-to/where-...mber-on-a-car/
Old Dec 15, 2024 | 11:31 AM
  #46
The group needs to seek help…professional help. a group discount would probably be best😂😂😂😂
Old Dec 15, 2024 | 11:56 AM
  #47
Just one. You.
Old Dec 15, 2024 | 12:11 PM
  #48
Wouldn’t know. I don't golf. I didn't even know the tees are lit.
Or was that illiterate for something else?
Old Dec 15, 2024 | 12:28 PM
  #49
The numbskullery is outstanding
Old Dec 15, 2024 | 12:39 PM
  #50
Old Dec 15, 2024 | 12:42 PM
  #51
1966 Olds Chassis service Manual 😉
Old Dec 15, 2024 | 12:46 PM
  #52
66 chassis manual “serial number on transmission” 😳
Old Dec 15, 2024 | 12:50 PM
  #53
66 Turbo 400 serial number location
Old Dec 15, 2024 | 01:04 PM
  #54
66 Factory chassis manual, thick like brick
serial number mentions = many
derivative mentions = zero
^^^this is what my help found^^^
Old Dec 15, 2024 | 01:23 PM
  #55
72455's Avatar
1972 U code Supreme
Wow...you've really lost a lot of sleep over this, haven't you? "VIN derivatives, derivative of the VIN"...what difference does it make how it's worded? At the end of the day, all that matters is that the numbers match...geez.
Old Dec 15, 2024 | 01:24 PM
  #56
It's hard to find good help.
Old Dec 15, 2024 | 01:48 PM
  #57
HighwayStar 442's Avatar
Beating {Flogging, just in case a all caps is watching} a dead horse for one more ride! Its a capital letters thing.
Old Dec 15, 2024 | 01:55 PM
  #58
TK-65's Avatar
Arguing the meaning of words. Imagine putting such effort into something that was productive.
Old Dec 15, 2024 | 01:56 PM
  #59
72455's Avatar
1972 U code Supreme
^^^x2
Old Dec 15, 2024 | 05:31 PM
  #60
JohnnyBs68S's Avatar
It says it’s a “derivative of the VIN”, not the VIN derivative.
ROTFLMAO Now there's a logical summersault that would make anyone dizzy. And the best part is that you don't even realize how silly that make you look, LOL.
IIRC, GM didn't begin to use VIN DERIVATIVES until '68, so bringing out documents from '66 to prove your point is beyond worthless:
Here's a shovel. Keep digging.
Old Dec 15, 2024 | 08:05 PM
  #61
You all failed. None of you can even acknowledge the mountains of docs , by GM, that call it a serial number
I guess if you don’t look and acknowledge, it didn’t happen right?
you guys act like cult members 😂😂😂😂. Even after you found out the cult leader lied to you about everything,, you just refuse to believe you were duped
Old Dec 15, 2024 | 08:30 PM
  #62
I am so sorry that your Daddy did not love you. Sad!
That you to have to attack, call people names and add many 😂 emojis. To feel superior.
To bad, I think you can build a great Olds engine. You just have too many daddy issues.
numbskullery, that is funny as all ****!!
Old Dec 15, 2024 | 09:09 PM
  #63
1965CutlassGuy's Avatar
9 thats what I mean 11
That is like saying you are a citizen of Canada, but you are not a Canadian Citizen.
they both mean the same thing
Old Dec 15, 2024 | 10:56 PM
  #64
The only hope for him now is that a concerned relative will read this thread and have him committed, finally getting him the help he so desperately needs.
Old Dec 16, 2024 | 02:35 AM
  #65
the cult beliefs are strong today…must believe, MUST BELIEVE!!!!!! 🤪🤡
Old Dec 16, 2024 | 02:52 AM
  #66
TK-65's Avatar
What exactly is your point to this?
Old Dec 16, 2024 | 03:33 AM
  #67
exactly…next time it’s called a serial number, like what GM calls it’s, don’t lose your mind.
Old Dec 16, 2024 | 03:36 AM
  #68
how many times do I have to say it..good lord. when someone calls it’s a serial number..which is EXACTLY what it’s called by GM…don’t freak out .
it’s the freaking bout and blasting the person for being correct.
now, don’t ask again “what’s my point”
Old Dec 16, 2024 | 03:38 AM
  #69
1972 and all others years are the same..look at the right side of this 72 chart..see, serial number
Old Dec 16, 2024 | 04:14 AM
  #70
More lessons for the children.
the above 70 W31 has a serial number(yes, it says serial number on the original GM sales order) 336870M316675
the original block would be stamped
30M316675
now, if the block stamping is a derivative(derived from or part of)of the VIN, like everyone is saying , 30M316675 would be like it is, in it’s entirety, all 9 digits, unchanged from beginning to end, nothing taken away or added to make it a derivative of the VIN…it’s not
it’s different…only M316675 in its order is part of the VIN, and of that, only the last 6 digits make it the unique serial number to prove the block is original to the car…that’s why it’s called serial or sequence number by GM
a serial number or sequence number can only be unique to one item.. a derivative can be applied to many items, therefore, it can’t be called a derivative on the block because derivative does not mean unique….the serial number is unique.
when you are describing one car and its unique # , the word serial number is used. that’s why you see serial number all over the place in GM docs..
you kids only got till next June for this to sink in, or you’ll be in the special Ed class next year
Old Dec 16, 2024 | 04:54 AM
  #71
TK-65's Avatar
Dude you’re arguing about the meaning of a number GM pulled out of their *** to label a car for the government. Not even the meaning of the number you’re losing your mind over the name they gave it.
Old Dec 16, 2024 | 04:59 AM
  #72
TK-65's Avatar
I’m going to start calling it chassis number instead.
jsjr74
Jun 2, 2021 02:31 PM
Cweber74
Sep 26, 2019 07:50 PM
Jabenge
Dec 20, 2017 06:52 PM
TheFarens
Oct 10, 2016 11:08 AM
