W-25 OAI fiberglass hood question...
Old Dec 11, 2020 | 06:40 PM
vCode442's Avatar
Vincit qui se vincit
I seem to open and close my hood quite often - checking fluids, cleaning under hood - you know the drill.
Hood is original GM not re-pop.
So is it better to leave it up, or continually open and close - typically I just lower it to a resting position and not close it all the way. Each lift seems to be an opportunity to exacerbate an already present (3 years +) very small fiberglass ‘stress crack’ - thoughts? Thank you
Old Dec 11, 2020 | 06:48 PM
Funkwagon455's Avatar
I don’t believe that opening/closing the hood with normal exertion will cause stress fractures. If your hood is 50 years old, the gel coat will most likely fail from engine heat, ultraviolet light, age and vibrations from the engine/road before simply opening and closing. I would not personally consider normal pm operations a hazard provided that your hinges are properly lubricated.
Old Dec 11, 2020 | 07:12 PM
vCode442's Avatar
Thanks, I appreciate your feedback, yes hinges are properly lubricated. Neighbors, family and friends crack jokes regarding how often I’m under the hood, and it got me wondering if I’m doing any harm to the fiberglass with frequent up/ down movement.
Old Dec 11, 2020 | 11:00 PM
Do it smoothly, slowly, and with both hands.
Old Dec 12, 2020 | 05:37 AM
Bfg's Avatar
Bfg
That’s what my wife says!
Old Dec 12, 2020 | 05:55 AM
The trick is to be sure the hinges are well lubricated. Unnecessary loads on the hood come from having to overcome friction in the hinges.
Old Dec 12, 2020 | 07:19 AM
vCode442's Avatar
Lubrication, both hands, slowly, smoothly...... got it! Thanks guys
Old Dec 12, 2020 | 09:27 AM
There any trick to that or simply work some axle grease in the joints?
Old Dec 12, 2020 | 09:38 AM
I use the spray can white lithium grease. The only problem is that it makes a mess.
Old Dec 12, 2020 | 09:45 AM
Thanks for warning. I shall do.
Old Dec 12, 2020 | 09:51 AM
When I had my hinges rebuilt, they came back with the recommendation of using Sea Foam Deep Creep to lubricate them. I suspect maybe less residual clean up. Of course lithium grease is also an excellent choice as well.
Old Dec 12, 2020 | 10:55 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Get a Zoom oiler and fill it with 30W oil.
A drop every so often followed by a wipe with a rag when it runs.
I get mine at my local HVAC supply house.
Amazon Amazon
Old Dec 12, 2020 | 11:02 AM
Not closing it fully would probably be beneficial, just don’t forget to latch it before driving!
GM never designed these cars with the mindset that they would still be on the road after 50 years. If all you have is a couple small cracks, I’d say that’s pretty impressive. I bet there isn’t a aftermarket hood that would hold up to daily use that would last half as long.
mcgeekgirl
Body work
Jan 18, 2020 03:11 AM
crank shaft
Apr 11, 2019 04:42 PM
69ishHoliday
Body work
Nov 19, 2013 06:05 AM
sworthy555
Feb 14, 2011 06:44 PM
sleeton
Jan 22, 2010 06:40 AM
