u joint help please
Old Jul 27, 2014 | 09:18 PM
1969cutlazz's Avatar
u joint help please
I've got a 69 cutlass with the type O rear end. Just picked up a nice chevy 12 bolt out of a 69 chevelle. My u joint is not mateing to the yoke on the 12 bolt chevy rear end. Can anyone tell me if theres a different u joint I need to use or do I need to buy a whole new yoke and u joint? Ive looked over some other threads on this but can't find an answer. Thanks
Old Jul 27, 2014 | 09:53 PM
2blu442's Avatar
They make a u-joint to do what you want. I've found them in local NAPA stores. Tell your favorite parts store what you doing and he should be able to come up with it. If I remember right Oldsmobile is longer across and may have larger caps. Then the chevy is shorter across and possibly smaller caps.
John
Old Jul 27, 2014 | 10:11 PM
Yes. The caps are larger not fitting into the chevy yoke. My local part store kids don't know anything unless its a Honda. hopefully someone here can give me a part number of what exactly I need.
Old Jul 27, 2014 | 10:37 PM
Brian Trick posted the part number for that conversion u-joint a while back. I couldn't find the part number but a web search revealed you need a 1310 to 3R conversion joint.
https://classicoldsmobile.com/forums...ft-length.html
Edit: part numbers on this site
http://www.dennysdriveshaft.com/p201...reaseable.html
From what I found, the # for the U joint you need is 3130 for the greasable one.
Old Jul 28, 2014 | 12:01 AM
Ok so I need a 1310 to GM 3R?? Im not seeing anything for a 3103 u joint.
Old Jul 28, 2014 | 12:32 AM
Is Spicer brand part number 5-3022X a good part number? Showing thats their part number for the 1310 to GM 3R conversion.
Old Jul 28, 2014 | 01:10 PM
I made a typo in my post above: the conversion u-joint number is 3130.
I edited the above post to correct the number.
aquabird
Oct 2, 2013 10:34 PM
nonhog
Drivetrain/Differentials
Sep 13, 2011 08:58 PM
cluelesscutlass
Aug 18, 2011 01:56 AM
defiant1
Oct 29, 2010 12:41 PM
drtdobber
Feb 14, 2007 01:16 PM
