trying to get my temp guage to work for my 85 delta 88
Old May 20, 2012 | 12:58 PM
ELECMAN's Avatar
When i bought the car the guy added the original set of factory guages.I think this only came on the station wagon version.The temp sender there only works with the idiot light.The temp guage only uses a single wire does anybody know which temp sender would work with my guages
Old May 20, 2012 | 03:47 PM
fdwheelman's Avatar
I believe its bwd wt203. I got mine from advance listed under 70 cutlass with gauges. However, now my light is inop. Working on a solution for that....
Old May 20, 2012 | 05:44 PM
ELECMAN's Avatar
CALLED UP ROCK AUTO THEY TOLD ME i NEED THIS ONE STANDARD MOTOR PRODUCTS Part # TX3 {Click Info Link for Alternate/OEM Part Numbers05744030, 10045847, 12146312, 15326386, 213310, 21352, 21372, 213928, 25036708, 25036979, 25037182, 3850397, 38503975, 805218T, 8100458470, 8121463120, 8121463121, 8132906, 8133450, 8153263860, 8250360920, 8250369790, 8983502327, J3241950} Thread Size - NPT: 3/8" x 18 Dryseal Thread; Terminal Type: Pins; Terminal Gender: Male; Direct OE Replacement; Number of Terminals: 2; Connector Gender: Female
The problem is the car didnt come with guages in my delta 88 There are two wires at the sender a Green and a Green/black one has power i want to get this sender thats above to also work with my temp light too how can i do this thanks
Old May 20, 2012 | 07:06 PM
fdwheelman's Avatar
Right... That would be correct for 85...
However, if I remember doing my homework right, the idiot light only is a one wire. My 78 was.
I have an 84 A4 intake in the garage, I'll look at it in the morning for you and compare it to my 78's 16. If I can grab you some pics, I will. I'll also slide some part numbers in there.
But I am sure that what I have in the intake of my Delta is what you would put in a 70-72 Cutlass with Gauges - 78 Cutlass with gauges - 78 Delta/98/CC with gauges.... I too converted to what is referred to as a Rallye Pack for the Delta.
I am however interested in hearing about where the two wires from the sensor above can go. If I can feed my gauge with one wire and my light with other, I'll be happy as a pig in poop!
Old May 21, 2012 | 07:30 AM
The gauges were optional on all the RWD B/C-body cars, not just the wagons. The two wire sender is used for both the idiot light and the gauge. One wire goes to the light, the other to the gauge. Yes, it matters which is which.
Old May 21, 2012 | 09:23 PM
fdwheelman's Avatar
I'm game Joe... Any idea of which feeds which?
I have the gauge wired straight, so the idiot light is just cut and taped. I'd love to get both working again. I also have a new harness as well, ready to plug in.
Old May 22, 2012 | 05:11 PM
ELECMAN's Avatar
Joe is correct looking at the electrical drawing i have.The only problem is when i looked up the temp sender/switch there are so many of them at rockauto.Don't know which one.does anybody now
Old May 22, 2012 | 05:20 PM
Redog's Avatar
Leave the idiot light one alone.
For the gauge there are 2
http://shop.advanceautoparts.com/web...RPSENSAMS_____
Or
I remember is being the WT359Z gauge, becuase it was smaller threads and higher priced. I bought both and tried both and took the other one back. Both fit my 22mm O2 Sensor socket wrench as well as the vacuum switch I took out
Old May 23, 2012 | 06:59 PM
mike's88's Avatar
Not really a hijack, but looking at my 78 fsm, there's a "fuel econemy gauge" which is basically a vaccum gauge. Wouldn't that be a cool find?
Old May 24, 2012 | 05:54 AM
fdwheelman's Avatar
I've looked for one, but it is a plate much like the Rallye pack, and it goes in the place of the Rallye pack. I could either have a vac gauge or a rallye pack... hehehehe
JpMotorsports
Oct 16, 2013 02:24 PM
ELECMAN
Jun 11, 2012 07:31 PM
Finn5033
Apr 10, 2012 09:23 AM
lmarquette
Mar 6, 2012 03:10 PM
toplessrocket
Jan 30, 2009 01:23 AM
