Trunk weather strip gap?
Old Dec 2, 2018 | 04:41 PM
Platinum69's Avatar
Has anyone run into this problem? Or is this normal? If so what was your solution on fixing it? I think maybe the metal needs pulled
up towards the seal. Thanks
Old Dec 2, 2018 | 04:47 PM
Gerald Nickels's Avatar
Back the camera up to get a better view. Way to close.
Old Dec 2, 2018 | 05:32 PM
Platinum69's Avatar
Old Dec 2, 2018 | 06:44 PM
jensenracing77's Avatar
Does it line up good along the quarters? You can adjust it to close more if it needs it along the quarters. If not then you will have to pull the metal up. I had an old original paint car that was like that from things being put in the trunk and bending it over the years. I had to get inside the trunk with the lid closed and smack it is spots with a rubber hammer till it was all sealed up. On a repaint it is best to look at this before pulling the car apart.
Old Dec 2, 2018 | 08:25 PM
Platinum69's Avatar
I think it lines up nice, was just painted.
Old Dec 3, 2018 | 12:19 PM
I had a similar issue with the 71 convertible - a previous owner pulled a horse trailer with it and I suppose loaded large bags of horse feed into the trunk, which collapsed the center of the vertical panel where the seal installs so that there was a very large gap when the trunk was closed. I "corrected" it by grabbing the seal lip area with both hands and pulling upwards as hard as I could. The center area where the seal installs moved upwards over 1/2" and closed the gap nicely.
Old Dec 3, 2018 | 03:19 PM
Platinum69's Avatar
I guess that's what I'll have to do then. I'm pretty happy with the alignment on the quarters. Thanks for the input
Old Dec 3, 2018 | 05:53 PM
This is what I done at first. I had to fine tune small spots with the rubber hammer.
drentz
Aug 25, 2015 10:32 AM
Sully69
Feb 26, 2015 08:58 AM
RROLDSX
Feb 20, 2014 05:58 PM
rlang
Jun 26, 2013 10:55 AM
MN71W30
Paint
May 26, 2010 06:48 PM
